path: root/configs/chromebook_link_defconfig
2015-01-23x86: Drop the x86_fb driverSimon Glass
Now that we have a full VESA driver we may as well use that. We need to support the VESA layer being set up by early start-up code or by running a VGA ROM. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: Make chromebook_link the default board for corebootBin Meng
Change SYS_CONFIG_NAME and DEFAULT_DEVICE_TREE to chromebook_link which is currently the only real board officially supported to run U-Boot loaded by coreboot. Note the symbolic link file chromebook_link.dts is deleted and link.dts is renamed to chromebook_link.dts. To avoid multiple definition of video_hw_init, the CONFIG_VIDEO_X86 define needs to be moved to arch/x86/cpu/ivybridge/Kconfig. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-21x86: Add chromebook_link boardSimon Glass
This board is a 'bare' version of the existing 'link 'board. It does not require coreboot to run, but is intended to start directly from the reset vector. This initial commit has place holders for a wide range of features. These will be added in follow-on patches and series. So far it cannot be booted as there is no ROM image produced, but it does build without errors. Signed-off-by: Simon Glass <sjg@chromium.org>
