path: root/configs/chromebook_link_defconfig
2019-06-21configs: Resync with savedefconfigTom Rini
2019-02-20sound: x86: link: Add sound supportSimon Glass
Add sound support for link, using the HDA codec implementation. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-02-20x86: link: Increase malloc size and decrease code sizeSimon Glass
At present link does not boot since it has outgrown its pre-relocation malloc() size and its assigned code area. Increase the former and drop EFI loader support, which adds about 45KB! Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-11-13configs: Resync with savedefconfigTom Rini
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Migrate CONFIG_LAST_STAGE_INIT to KconfigMario Six
Migrate the CONFIG_LAST_STAGE_INIT option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2017-09-16x86: Enable early timer for chromebook_linkSimon Glass
Enable this option for link so that the timer is available earlier. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-08-24x86: kconfig: Imply CMD_PCIBin Meng
Let's imply the 'pci' command to access the de facto interconnect bus in an x86 system. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-08-01x86: Switch all boards to use DM SCSIBin Meng
After MMC is converted to DM, convert to use DM SCSI as well for all x86 boards and imply BLK for both MMC and SCSI drivers. CONFIG_SCSI_DEV_LIST is no longer used. Clean them up. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Let board select SPI flashBin Meng
Only a specific type of SPI flash exists on a board, having board Kconfig to select the SPI flash seems to make more sense. Other flash types are not necessary except coreboot, which implies all available flash drivers there. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: ivybridge: kconfig: Imply platform specific driversBin Meng
Imply drivers that are working with Ivybridge platform in the platform Kconfig. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Imply DM uclass driversBin Meng
Now that all x86 boards have been converted to use DM, we can imply these uclass drivers (DM_ETH, DM_RTC, DM_USB, DM_VIDEO) from the top level. Previously DM_GPIO, DM_KEYBOARD, DM_SERIAL, DM_SPI, DM_SPI_FLASH are selected. Change to use 'imply' to allow them to be removed. Note with this change, chromebook_link64 build fails: common/built-in.o:(.data.env_htab+0xc): undefined reference to 'env_flags_validate' lib/built-in.o: In function `hsearch_r': lib/hashtable.c:380: undefined reference to 'env_callback_init' lib/hashtable.c:382: undefined reference to 'env_flags_init' make[1]: *** [spl/u-boot-spl] Error 1 CONFIG_SPL_ENV_SUPPORT is required for chromebook_link64 to build again. This is just a workaround as it is not needed at all. See commit bda40d5 "x86: qemu: Add a config for 64-bit U-Boot" for the same issue seen on QEMU 64-bit target. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Select OF_CONTROLBin Meng
This is a must have for all x86 boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Imply ENABLE_MRC_CACHE in the platform KconfigBin Meng
Platform knows whether MRC cache is implemented, but using it can be a choice of a specific board. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Select PCI and DM_PCIBin Meng
PCI is the de facto interconnect bus in an x86 system. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Select USE_PRIVATE_LIBGCCBin Meng
x86 is using the built-in libgcc implementation and this cannot be turned off. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Select TIMER and X86_TSC_TIMERBin Meng
Without a timer, U-Boot just doesn't boot. This is not something we can turn off. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-31configs: Resync with savedefconfigTom Rini
2017-07-30arch/x86: Select USB before selecting host driverAndy Shevchenko
Kbuild complains if USB is not selected before any of host driver. warning: (X86) selects USB_EHCI_HCD which has unmet direct dependencies (USB) warning: (X86) selects USB_EHCI_HCD which has unmet direct dependencies (USB) Select it for X86. Fixes: 64d6ac5bc4a9 ("Kconfig: USB: Migrate CONFIG_USB_EHCI_HCD users to Kconfig") Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> [bmeng: Update all x86 boards' defconfig files to remove CONFIG_USB] Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11x86: Move link to use driver model for SCSISimon Glass
As a demonstration of how to use SCSI with driver model, move link over to use this. This patch needs more work, but illustrates the concept. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11Convert CONFIG_SCSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SCSI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-04-18x86: config: Enable dhrystone command for linkSimon Glass
Enable this command so we can get an approximate performance measurement. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-02-07x86: link: Set up device tree for SPLSimon Glass
Add the correct pre-relocation tag so that the required device tree nodes are present in the SPL device tree. On x86 it doesn't make a lot of sense to have a separate SPL device tree. Since everything is in the same ROM we might as well just use the main device tree in both SPL and U-Boot proper. But we haven't implemented that, so this is a good first step. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-01-28disk: convert CONFIG_MAC_PARTITION to KconfigPatrick Delaunay
2016-10-23Convert CONFIG_USB_KEYBOARD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USB_KEYBOARD Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Fixup MPC86* configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_CONSOLE_SCROLL_LINES to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CONSOLE_SCROLL_LINES Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VGA_AS_SINGLE_DEVICE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VGA_AS_SINGLE_DEVICE Once we migrate to driver model for video, we should be able to drop this option. Signed-off-by: Simon Glass <sjg@chromium.org>
