path: root/configs/chromebook_link_defconfig
2016-03-22defconfig: Reorder boards' defconfig filesBin Meng
Some boards' defconfig files are out of order. Clean this up. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-03-14Correct defconfig orderingSimon Glass
Various boards have the wrong Kconfig ordering now. To avoid a misleading diff in the next patch, reorder the configuration correctly. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-24x86: chromebook_link: Enable the syscon uclassSimon Glass
We will use a system controller to model the Intel Management Engine. Enable this for link. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24x86: ivybridge: Use the I2C driver to perform SMbus initSimon Glass
Move the init code into the I2C driver. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24x86: Enable DM_USB for link and pantherSimon Glass
Move these two boards to use driver model for USB. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24x86: ivybridge: Use common CPU init codeSimon Glass
The existing ivybridge code predates the normal multi-core CPU init, and it is not used. Remove it and add CPU nodes to the device tree so that all four CPUs are set up. Also enable the 'cpu' command. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-19vsprintf.c: Always enable CONFIG_SYS_VSNPRINTFTom Rini
Enabling this function always removes some class of string saftey issues. The size change here in general is about 400 bytes and this seems a reasonable trade-off. Cc: Peng Fan <peng.fan@nxp.com> Cc: Peter Robinson <pbrobinson@gmail.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Adrian Alonso <aalonso@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-12-01x86: Convert to use driver model timerBin Meng
Convert all x86 boards to use driver model tsc timer. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-30x86: Select the ns16550 debug UART for minnowmax, chromebook_linkSimon Glass
At present the debug UART is not selected which causes a build error. Correct this. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-10-21x86: chromebook_link: Enable the debug UARTSimon Glass
Add support for the debug UART on link. This is useful for early debugging. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-10-21x86: Move mrccache.[c|h] to a common placeBin Meng
mrccache implementation can be common for all boards. Move it from ivybridge cpu directory to the common lib directory. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-09-28x86: chromebook_link: Expand early malloc() memorySimon Glass
Now that PCI bridges are probed before relocation we need additional memory. Each PCI bridge takes 240 bytes at present since it uses the same uclass as the PCI controller. Probably we should split this out so that bridges have their own uclass. Expand the memory on link so that it works correctly. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-31tpm: Enable 'tpmtest' command for Chrome OS boards with TPMsSimon Glass
This command provides a few useful tests so enable it for common boards. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard<christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-31dm: tpm: Convert LPC driver to driver modelSimon Glass
Convert the tpm_tis_lpc driver to use driver model and update boards which use it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard<christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-31tpm: Convert board config TPM options to KconfigSimon Glass
Convert all TPM options to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard <christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-05x86: Move Chrome OS options to defconfigSimon Glass
Drop these from the header file and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-07-28x86: Enable DM RTC support for all x86 boardsBin Meng
Add a RTC node in the device tree to enable DM RTC support. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> (Squashed in 'x86: Fix RTC build error on ivybridge')
2015-07-14x86: Move VGA option rom macros to KconfigBin Meng
Move X86_OPTION_ROM_FILE & X86_OPTION_ROM_ADDR to arch/x86/Kconfig and rename them to VGA_BIOS_FILE & VGA_BIOS_ADDR which depend on HAVE_VGA_BIOS. The new names are consistent with other x86 binary blob options like HAVE_FSP/FSP_FILE/FSP_ADDR. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-29x86: Kconfig: Remove deprecated CONFIG_SYS_EXTRA_OPTIONSBin Meng
Currently all x86 boards still use CONFIG_SYS_EXTRA_OPTIONS to define the text base address. Since it is deprecated, just remove it and use CONFIG_SYS_TEXT_BASE directly. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-29x86: Kconfig: Divide the target selection to vendor/modelBin Meng
Let arch/x86/Kconfig prompt board vendor first, then select the board model under that vendor. This way arch/x86/Kconfig only needs concern board vendor and leave the supported target list to board/<vendor>/Kconfig. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: cros_ec: Convert cros_ec LPC driver to driver modelSimon Glass
This is the last driver to be converted. It requires an LPC bus and a special check_version() method. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: x86: pci: Convert chromebook_link to use driver model for pciSimon Glass
Move chromebook_link over to driver model for PCI. This involves: - adding a uclass for platform controller hub - removing most of the existing PCI driver - adjusting how CPU init works to use driver model instead - rename the lpc compatible string (it will be removed later) This does not really take advantage of driver model fully, but it does work. Furture work will improve the code structure to remove many of the explicit calls to init the board. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-23x86: Drop the x86_fb driverSimon Glass
Now that we have a full VESA driver we may as well use that. We need to support the VESA layer being set up by early start-up code or by running a VGA ROM. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: Make chromebook_link the default board for corebootBin Meng
Change SYS_CONFIG_NAME and DEFAULT_DEVICE_TREE to chromebook_link which is currently the only real board officially supported to run U-Boot loaded by coreboot. Note the symbolic link file chromebook_link.dts is deleted and link.dts is renamed to chromebook_link.dts. To avoid multiple definition of video_hw_init, the CONFIG_VIDEO_X86 define needs to be moved to arch/x86/cpu/ivybridge/Kconfig. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-21x86: Add chromebook_link boardSimon Glass
This board is a 'bare' version of the existing 'link 'board. It does not require coreboot to run, but is intended to start directly from the reset vector. This initial commit has place holders for a wide range of features. These will be added in follow-on patches and series. So far it cannot be booted as there is no ROM image produced, but it does build without errors. Signed-off-by: Simon Glass <sjg@chromium.org>
