path: root/configs/chromebook_jerry_defconfig
2016-09-16Convert CONFIG_SPL_POWER_SUPPORT to KconfigSimon Glass
2016-07-25cosmetic: rockchip: rk3288: pinctrl: fix config symbol namingHeiko Stübner
The rk3288 pinctrl is very specific to this soc, so should not hog the generic rockchip naming. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Acked-by: Simon Glass <sjg@chromium.org>
2016-05-26Rename reset to sysresetStephen Warren
The current reset API implements a method to reset the entire system. In the near future, I'd like to introduce code that implements the device tree reset bindings; i.e. the equivalent of the Linux kernel's reset API. This controls resets to individual HW blocks or external chips with reset signals. It doesn't make sense to merge the two APIs into one since they have different semantic purposes. Resolve the naming conflict by renaming the existing reset API to sysreset instead, so the new reset API can be called just reset. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-03-22defconfig: Reorder boards' defconfig filesBin Meng
Some boards' defconfig files are out of order. Clean this up. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-02-06rockchip: Drop old CONFIG_VIDEO_ROTATION optionSimon Glass
The option was renamed to CONFIG_CONSOLE_ROTATION and Rockchip boards were not updated. However this option is is not needed by default for Rockchip since we don't need a rotated console for current boards. So just remove the old option. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-26video: add CONFIG_I2C_EDID and disable CONFIG_DISPLAY by defaultAnatolij Gustschin
Enabling CONFIG_DISPLAY breaks building for some architectures (microblaze-generic), so we disable CONFIG_DISPLAY in Kconfig by default and enable this option in defconfigs. CONFIG_DISPLAY depends on CONFIG_I2C_EDID, so add and enable it in defconfigs, too. Signed-off-by: Anatolij Gustschin <agust@denx.de> Reported-by: Bin Meng <bmeng.cn@gmail.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2016-01-21rockchip: jerry: Enable EDP and HDMI video outputSimon Glass
Enable these devices using the VOPL video output device. We explicitly disable VOPB in the device tree to avoid it taking over. Since this device has an LCD display this comes up by default. If the display fails for some reason then it will attempt to use HDMI. It is possible to force it to fail (and thus fall back to HDMI) by puting 'return -EPERM' at the top of rk_edp_probe(). For now there is no easy way to select between the two. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: spl: Support full-speed CPU in SPLSimon Glass
Add a feature which speeds up the CPU to full speed in SPL to minimise boot time. This is only supported for certain boards (at present only jerry). Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: jerry: Enable the Chrome OS ECSimon Glass
Turn on the EC and enable the keyboard. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: jerry: Drop unused optionsSimon Glass
To reduce the SPL image size, drop the LED features. Jerry does not have an LED and we can leave out GPIO support also. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: Disable simple-bus in SPL for firefly-rk3288, jerrySimon Glass
This is not needed for booting, so drop it from SPL to save about 300 bytes. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: jerry: Enable the RK808 PMIC and regulatorSimon Glass
Enable this PMIC and regulator, which is used on jerry. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: Move firefly and jerry to use the full pinctrlSimon Glass
Use the full pinctrl driver in U-Boot proper. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: Use a separate clock ID for clocksSimon Glass
At present we use the same peripheral ID for clocks and pinctrl. While this works it is probably better to use the device tree clock binding ID for clocks. We can use the clk_get_by_index() function to find this. Update the clock drivers and the code that uses them. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: Use pwrseq for MMC start-up on jerrySimon Glass
This is defined in the device tree in Linux. Copy over the settings so that this can be used instead of hard-coding the reset line. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: Correct the defconfig orderSimon Glass
This has got out of sequence somehow. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-08rockchip: Fix the configuration for chromebook_jerrySimon Glass
Various updates did not make it through to this board. Also the instructions for building a SPI image are no-longer correct. Fix these so that Jerry can boot to a prompt again. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-12-01rockchip: Explicitly set CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LENSjoerd Simons
Now that u-boot relocates the malloc area in SPL to SDRAM, with the malloc area sitting below the SPL_STACK_R_ADDR the SPL_STACK_R_MALLOC_SIMPLE_LEN needs to be set explicitly for rockchip as its SPL_STACK_R_ADDR (512kb) is smaller then STACK_R_MALLOC_SIMPLE_LEN (1Mb). Using the same value as SYS_MALLOC_F_LEN (8kb) is enough to load u-boot from SD card. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01dm: core: Add SPL Kconfig for REGMAP and SYSCONhuang lin
Add SPL Kconfig for REGMAP and SYSCON, so REGMAP and SYSCON can remove from SPL stage. Signed-off-by: Lin Huang <hl@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-19rockchip: Turn on CONFIG_DEBUG_UART_NS16550 in defconfigsAriel D'Alessandro
No UART driver was specified in defconfig, thus DEBUG_UART_ALTERA_JTAGUART was incorrectly selected by default since commit 220e8021af96741bd7149ca9895e1f0c8a38d0bb added a new Altera UART driver. Signed-off-by: Ariel D'Alessandro <ariel@vanguardiasur.com.ar> Acked-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: Add basic support for jerrySimon Glass
This builds and displays an SPL message, but does not function beyond that. Signed-off-by: Simon Glass <sjg@chromium.org>
