Rename these options so that CONFIG_IS_ENABLED can be used with them.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
[trini: Fixup some incorrect renames]
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
Now that we have consistent usage, migrate this symbol to Kconfig.
Reviewed-by: Rick Chen <rick@andestech.com>
Enable CONFIG_MMC_PWRSEQ configuration about boards that is using
rockchip_dw_mmc driver.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Commit fe974716326c ("rockchip: rk3288: Allow setting up clocks in
U-Boot proper") fixes some clock issues when chainloading U-Boot on
rk3288 chromebooks. Part of that change is still available in veyron's
board_early_init_r() function. Since chain-loading U-Boot proper from
vendor firmware is possible on gru boards as well, do the same thing for
them too.
On rk3399, this needs to detect whether SPL was run via handoff, so
enable that and bloblist kconfigs it needs for chromebook_bob.
Signed-off-by: Alper Nebi Yasak <alpernebiyasak@gmail.com>
Reviewed-by: Kever Yang<kever.yang@rock-chips.com>
Update the config for chromebook_bob to support booting from SPI flash.
The existing SPL size is too small since ATF is needed, so double it.
Merge all outstanding changes from the current next branch in now that
we have released.
Due to how the Makefile logic is we currently get DM_SPI support in SPL
enabled by having DM_SPI enabled for full U-Boot but not having
CONFIG_SPL_DM_SPI set. Add this missing option to boards that were
inadvertently making use of it.
Cc: Adam Ford <aford173@gmail.com>
Cc: Akash Gajjar <akash@openedev.com>
Cc: Andy Yan <andy.yan@rock-chips.com>
Cc: Anup Patel <anup.patel@wdc.com>
Cc: Atish Patra <atish.patra@wdc.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Chee Hong Ang <chee.hong.ang@intel.com>
Cc: Chin-Liang See <clsee@altera.com>
Cc: Dalon Westergreen <dwesterg@gmail.com>
Cc: Dinh Nguyen <dinguyen@kernel.org>
Cc: Eugen Hristev <eugen.hristev@microchip.com>
Cc: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Cc: Jagan Teki <jagan@amarulasolutions.com>
Cc: Klaus Goger <klaus.goger@theobroma-systems.com>
Cc: Levin Du <djw@t-chip.com.cn>
Cc: Ley Foon Tan <ley.foon.tan@intel.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Luca Ceresoli <luca@lucaceresoli.net>
Cc: Mike Looijmans <mike.looijmans@topic.nl>
Cc: Nicolas Ferre <nicolas.ferre@microchip.com>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Palmer Dabbelt <palmer@dabbelt.com>
Cc: Paul Walmsley <paul.walmsley@sifive.com>
Cc: Pavel Machek <pavel@denx.de>
Cc: Peter Robinson <pbrobinson@gmail.com>
Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Suniel Mahesh <sunil@amarulasolutions.com>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: Wolfgang Grandegger <wg@aries-embedded.de>
Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip
- Add support for rockchip pmic rk805,rk809, rk816, rk817
- Add rk3399 board Leez support
- Fix bug in rk3328 ram driver
- Adapt SPL to support ATF bl31 with entry at 0x40000
- Fix the u8 type comparision with '-1'.
- Fix checkpatch warning for multi blank line and review signature.
Use the same SPL_STACK_R_ADDR in Kconfig instead of each board config;
default to 0x4000000(64MB) instead of 0x80000(512KB) for this address
can support all the SoCs including those may have only 64MB memory, and
also reserve enough space for atf, kernel(in falcon mode) loading.
After the ATF entry move to 0x40000, the stack from 0x80000 may be override
when loading ATF bl31.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
CONFIG_SYS_SPI_U_BOOT_OFFS
Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
[trini: Expose this for SPL_SPI_SUNXI for now]
RK3399 SPL only support FIT image for ATF bl31.
We needs SPL LIBCOMMON and LIBGENERIC for all boards,
so we can enable them by default and no need to define
in each board.
There is no difference in rk3399 board use for SYS_MALLOC_F_LEN,
so we can use default value.
Few SPL and U-Boot proper configs are common to all rk3399 target
defconfigs, move them and select it from platform kconfig.
Moved configs:
- SPL_ATF
- SPL_ATF_NO_PLATFORM_PARAM if SPL_ATF
- SPL_LOAD_FIT
- SPL_CLK if SPL
- SPL_PINCTRL if SPL
- SPL_RAM if SPL
- SPL_REGMAP if SPL
- SPL_SYSCON if SPL
- CLK
- FIT
- PINCTRL
- RAM
- REGMAP
- SYSCON
- DM_PMIC
- DM_REGULATOR_FIXED
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Add default SPL_FIT_GENERATOR py script for rockchip platforms if
specific target enabled SPL_LOAD_FIT.
So, this would help get rid of explicitly mentioning the default
SPL FIT generator in defconfigs. however some targets, like puma_rk3399
still require their own FIT generator so in those cases the default will
override with defconfig defined generator.
Reviewed-by: Paul Kocialkowski <paul.kocialkowski@bootlin.com>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
Bob is a 10-inch chromebook produced by Asus. It has two USB 3.0 type-C
ports, 4GB of SDRAM, WiFi and a 1280x800 display. It uses its USB ports
for both power and external display. It includes a Chrome OS EC
(Cortex-M3) to provide access to the keyboard and battery functions.
Support so far includes only:
- UART
- SDRAM
- MMC, SD card
- Cros EC (but not keyboard)
Not included:
- Keyboard
- Display
- Sound
- USB
- TPM
Bob is quite similar to Kevin, the Samsung Chromebook Plus, but support
for this is not provided in this series.
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
