After moving some USB gadget configs (USB_FUNCTIONS_*) to Kconfig it
turned out that following *_defconfig entries for RockChip are not
needed.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
This commit moves USB_FUNCTION_MASS_STORAGE config to Kconfig.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
CONFIG_ROCKCHIP_USB2_PHY
this patch enable rockusb support on rk3288 based device.
Signed-off-by: Eddie Cai <eddie.cai.linux@gmail.com>
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
Fastboot need a bunch of options to be operating properly, such as the
g_dnl gadget, the fastboot command, and some options that make sense. Since
fastboot is now part of Kconfig, make sure we have them right.
That will also reduce the boilerplate in the defconfigs.
Reviewed-by: Ćukasz Majewski <lukma@denx.de>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The g_dnl USB settings for the vendor ID, product ID and manufacturer are
actually common settings that can and should be shared by all the gadgets.
Make them common by renaming them, and convert all the users.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's
not strictly part of fastboot.
- Add some defaults for the fastboot buffer location and size
- Migrate all options listed in cmd/fastboot/Kconfig
- Cleanup the README
This syncs all of the currently Kconfig'd symbols out of the headers and
into the defconfig files. This has two exceptions, first am335x_evm
needs to be converted to DM in SPL and then it can stop undef'ing
CONFIG_DM_USB. Leaving this as-is results in a build failure, and
without work, run time failure. The other case is am43xx_evm.h and in
turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB
host mode in SPL, but still desire to have gadget mode in U-Boot proper.
CONFIG_CMD_SF_TEST
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
Since this driver can be used for rk8xx series pmic,
let's rename rk808 to rk8xx, to make it clear.
Configs parts are done by sed -i "s/RK808/RK8XX/g" `grep RK808 -lr ./`
Signed-off-by: Jacob Chen <jacob-chen@iotwrt.com>
1. add Kconfig for rockchip video driver, so that video port can be
selected as needed.
2. move VIDEO_ROCKCHIP option to new Kconfig for concision.
Signed-off-by: Eric Gao <eric.gao@rock-chips.com>
Drop indenting in Kconfig:
This originally started out as
"pinctrl: Kconfig: reorder to keep Rockchip options together"
and tried to keep the Rockchip-related config options together.
However, we now rewrite all chip-specific driver selections to start
with CONFIG_PINCTRL_ (with the inadvertent changes to related
Makefiles) and sort those alphabetically. And as this already means
touching most of the file, we also reformat the help text to not exceed
80 characters (but make full use of those 80 characters).
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
We convert CONFIG_PARTITION_UUIDS to Kconfig first. But in order to cleanly
update all of the config files we must also update CMD_PART and CMD_GPT to also
be in Kconfig in order to avoid complex logic elsewhere to update all of the
config files.
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Signed-off-by: Jagan Teki <jagan@openedev.com>
This commit was created as follows:
[1] Rename the option with the following command:
find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \
-type f -print | xargs sed -i -e 's/CONFIG_DWMMC/CONFIG_MMC_DW/g'
[2] create the entry for MMC_DW in drivers/mmc/Kconfig
(the prompt and help were copied from Linux)
[3] run "tools/moveconfig.py -y MMC_DW"
[4] add "depends on MMC_DW" to the MMC_DW_ROCKCHIP entry
[5] Clean-up doc/README.socfpga by hand
I am trying to make all DesignWare-based driver options prefixed
with CONFIG_MMC_DW_.
This commit was generated as follows:
find . -name .git -prune -o -type f -print | \
xargs sed -i -e 's/ROCKCHIP_DWMMC/MMC_DW_ROCKCHIP/g'
Generated by "tools/moveconfig -s".
This will make config moves easier.
This adds support for the Asus Chromebit, and RK3288-based device designed
to plug directly into an HDMI monitor. The device tree file comes from
Linux v4.8.
