CONFIG_SYS_DFU_MAX_FILE_SIZE to Kconfig
Currently the config options CONFIG_SYS_DFU_DATA_BUF_SIZE and
CONFIG_SYS_DFU_MAX_FILE_SIZE are being set in include/configs/<board>.h
files and also in <board_name>_defconfig files without a Kconfig option. It
is easier for users to set these configs in defconfig files than in config
header files as they are a part of the source code.
Add Kconfig symbols, and update the defconfigs by using tools/moveconfig.py
script.
Suggested-by: Pratyush Yadav <p.yadav@ti.com>
Signed-off-by: Aswath Govindraju <a-govindraju@ti.com>
Activate ARCH_SUPPORT_PSCI as other TEGRA124 target and remove
CONFIG_ARMV7_PSCI and CONFIG_ARMV7_PSCI_NR_CPUS in configs file as they
are migrated in Kconfig.
Select CONFIG_ARMV7_PSCI_0_1 (the first PSCI version),
because CONFIG_ARMV7_PSCI_0_2 and CONFIG_ARMV7_PSCI_1_0
are not activated in this product.
This patch depend on the previous serie [1].
I don't test this patch on real hardware but
after this patch the size of the binary don't change.
In .config we have:
CONFIG_ARCH_SUPPORT_PSCI=y
CONFIG_ARMV7_PSCI=y
# CONFIG_ARMV7_PSCI_1_0 is not set
# CONFIG_ARMV7_PSCI_0_2 is not set
CONFIG_ARMV7_PSCI_0_1=y
CONFIG_ARMV7_PSCI_NR_CPUS=4
In u-boot.cfg, this patch only add the 2 lines
#define CONFIG_ARCH_SUPPORT_PSCI 1
#define CONFIG_ARMV7_PSCI_0_1 1
[1] "Convert CONFIG_ARMV7_PSCI_1_0 and CONFIG_ARMV7_PSCI_0_2 to Kconfig"
http://patchwork.ozlabs.org/project/uboot/list/?series=184029
Regards
Patrick
END
Reviewed-by: Peter Chubb <peter.chubb@data61.csiro.au>
Signed-off-by: Tom Warren <twarren@nvidia.com>
CONFIG_SYS_MMC_ENV_DEV
CONFIG_SYS_MMC_ENV_PART
Note that with this conversion we now have consistent behavior with
respect to ensuring that we have always selected the correct MMC
device and hardware partition.
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
Have this symbol follow the pattern of all other such symbols.
Signed-off-by: Trevor Woerner <twoerner@gmail.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
Migrate USB_EHCI_TEGRA from headers to Kconfig
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Cc: Tom Warren <twarren@nvidia.com>
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Marcel Ziswiler <marcel.ziswiler@toradex.com>
Cc: Peter.Chubb@data61.csiro.au
Cc: Lucas Stach <dev@lynxeye.de>
Cc: Stefan Agner <stefan.agner@toradex.com>
Cc: Alban Bedel <alban.bedel@avionic-design.de>
Cc: Allen Martin <amartin@nvidia.com>
Migrate SYS_I2C_TEGRA from headers to Kconfig
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
We enabled CONFIG_ISO_PARTITION by default for distro boot, so that U-Boot
could load distro images that usually get shipped as iso images. These images
usually come with a board agnostic boot environment.
However, there is very little point in having ISO support enabled (for anyone
really) in SPL, as the whole idea of SPL is to load U-Boot proper which again
is board specific. So the fact that we enable ISO support in U-Boot proper does
not mean at all that we want ISO support in U-Boot SPL.
Hence, let's remove the Kconfig dependency. Along the way, let's also clean up
all those default configs that disabled SPL ISO support.
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
cmd/Makefile has:
ifdef CONFIG_FPGA
obj-$(CONFIG_CMD_FPGA) += fpga.o
endif
which means that if CONFIG_FPGA is not set, CONFIG_CMD_FPGA silently
does nothing. Let's remove that Makefile conditional and instead express
this equivalent dependency in Kconfig, so a lot of redundant
# CONFIG_CMD_FPGA is not set
can be removed from board defconfigs that don't actually have an FPGA.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
The g_dnl USB settings for the vendor ID, product ID and manufacturer are
actually common settings that can and should be shared by all the gadgets.
Make them common by renaming them, and convert all the users.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig.
Update defconfigs.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on
USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and
LAN78XX options under new menu. Finally update the defconfigs that need
CONFIG_USB_HOST_ETHER.
CONFIG_CMD_PCI
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Convert this PMIC driver to driver model and fix up other users. The
regulator and GPIO functions are now handled by separate drivers.
Update nyan-big to work correct. Three boards will need to be updated by
the maintainers: apalis-tk1, cei-tk1-som. Also the TODO in the code re
as3722_sd_set_voltage() needs to be completed.
Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
Tested-on: Jetson-TK1
Enable CONFIG_DM_MMC_OPS and CONFIG_BLK for all Tegra devices. This moves
Tegra to use driver model fully for MMC.
Migrate the rest of the users of CONFIG_USB_EHCI_HCD over to Kconfig.
For a few SoCs, imply or default y this if USB is enabled. In some
cases we had not already migrated to CONFIG_USB so do that as well.
CONFIG_PMIC_AS3722
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Signed-off-by: Jagan Teki <jagan@openedev.com>
A number of platforms had been using the distro default feature before
it was moved to Kconfig but did not enable the new Kconfig option when
it was enabled. This caused a regression in terms of features and this
introduces breakage when more things move to Kconfig.
Add 'PCI' as a menu option and migrate all existing users.
CONFIG_SYS_STDIO_DEREGISTER
This option should never be enabled in SPL, so use
CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option.
[trini: Re-sync]
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
These two options go together and it is best to do the conversion in one
step. So enable DM_MMC_OPS by default if DM_MMC is enabled.
To speed up conversion to CONFIG_BLK, enable it by default when DM_MMC is
enabled.
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for
CMD_DFU (as we must have the DFU command enabled to do anything DFU).
Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add
options for all of the back end choices that DFU can make use of.
Cc: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
The Colorado TK1 SOM is a small form factor board similar to the
Jetson TK1. The main differences lie in the pinmux, and in that the
PCIe controller is set to use in 4lanes+1lane, rather than 2+2.
The pinmux header here was generated from a spreadsheet provided by
Colorado Engineering using the tegra-pinmux scripts. The spreadsheet
was converted from v09 to v11 by me.
Signed-off-by: Peter Chubb <peter.chubb@data61.csiro.au>
