path: root/configs/canyonlands_defconfig
2017-01-28disk: convert CONFIG_MAC_PARTITION to KconfigPatrick Delaunay
2015-08-18of: flip CONFIG_SPL_DISABLE_OF_CONTROL into CONFIG_SPL_OF_CONTROLMasahiro Yamada
As we discussed a couple of times, negative CONFIG options make our life difficult; CONFIG_SYS_NO_FLASH, CONFIG_SYS_DCACHE_OFF, ... and here is another one. Now, there are three boards enabling OF_CONTROL on SPL: - socfpga_arria5_defconfig - socfpga_cyclone5_defconfig - socfpga_socrates_defconfig This commit adds CONFIG_SPL_OF_CONTROL for them and deletes CONFIG_SPL_DISABLE_OF_CONTROL from the other boards to invert the logic. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-06-10dts: Disable device tree for SPL on all boardsSimon Glass
We plan to enable device tree in SPL by default. Before doing this, explicitly disable it for all boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-05-10kconfig: Move REGEX to KconfigJoe Hershberger
Having this as a Kconfig allows it to be a dependent feature. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: Change from OF_SEPARATE to OF_EMBEDStefan Roese
This is necessary, as ppc4xx has the reset vector located at the end of the U-Boot image. This needs to be flashed to the end of the NOR flash. Adding the dtb to the main U-Boot image will break booting on ppc4xx. This patch now embeds the dtb in the U-Boot image instead. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: Use CONFIG_OF_CONTROL for canyonlands boardsSimon Glass
Enable CONFIG_OF_CONTROL so that U-Boot on these three boards uses a device tree for its configuration. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: Move CANYONLANDS/GLACIER/ARCHES to KconfigSimon Glass
Move these options to Kconfig and remove them from the CONFIG files. Signed-off-by: Simon Glass <sjg@chromium.org>
