* Drop legacy /boot/PPTImage.md5 check
* Update device tree naming
* Update t30args#0 root cmd line property to support latest kernel
versions (root=/dev/mmcblk0p2 for linux < 4 and
root=/dev/mmcblk1p2 for linux >= 4)
* Add custom bootloader version string
* Destroy invalid dtb at ${dtbaddr} and configuration script at
${cfgaddr} to ensure proper boot in warm restart case.
Signed-off-by: Bernhard Messerklinger <bernhard.messerklinger@br-automation.com>
Reviewed-by: Wolfgang Wallner <wolfgang.wallner@br-automation.com>
Commit 0ea4fc4dcf90 ("board/BuR: invalidate ${dtbaddr} before cfgscr")
destroys the boot targets b_t30lgcy#0 and b_t30lgcy#1. The reason behind
this is, that b_t30lgcy#0 and b_t30lgcy#1 both load the for booting
needed device trees from mmc and the cfgscr script patches those. Because
of this, cfgscr is not allowed to destroy the previously loaded device
tree otherwise cfgscr will fail.
This patch moves the device trees invalidation on warm restart to the
PREBOOT cmd to fix that issue.
Fixes: 0ea4fc4dcf90 ("board/BuR: invalidate ${dtbaddr} before cfgscr")
Commit 6337d53fdf45 ("arm: dts: sync am33xx with Linux 5.9-rc7") syncs
the am335x device tree with the latest linux kernel am335x device tree.
That causes problems with device tree in SPL stage.
To fix the issues CONFIG_SPL_OF_TRANSLATE must be set to handle the
synced bus addresses correctly.
A custom U-Boot device tree is also needed since the SPL build removes
bus properties from bus nodes which are not explicitly marked with the
u-boot,dm-spl or u-boot,dm-pre-reloc flag. Therefore all parent buses of
the in the SPL needed devices must be marked with u-boot,dm-pre-reloc.
Also since there is no driver for "ti,sysc" compatible property in SPL
the buses marked with this compatible string must also be marked with
compatible = "simple-bus" to make the underlying devices visible in
SPL. Otherwise the matching device drivers aren't found and the uclass
drivers are dropped.
CONFIG_SYS_BOOTM_LEN
As part of this, rework error handling in boot/bootm.c so that we pass
the buffer size to handle_decomp_error as CONFIG_SYS_BOOTM_LEN will not
be available to host tools but we do know the size that we passed to
malloc().
Cc: Soeren Moch <smoch@web.de>
The "autoload" environment variable is always checked with env_get_yesno
as it can be set to any form of no. The default behavior of
env_get_yesno is to return -1 on variables that are not set, which acts
as true in general (we test for non-zero return). To convert
CONFIG_SYS_AUTOLOAD to Kconfig, given that it was almost always used to
set autoload to no, first rename to CONFIG_SYS_DISABLE_AUTOLOAD for
consistency sake. Then, make it so that if enabled we set autoload=0 in
the default environment. Migrate all platforms which set
CONFIG_SYS_AUTOLOAD to non-true or that set autoload to false in their
default environment to using CONFIG_SYS_DISABLE_AUTOLOAD
CONFIG_SYS_SPL_MALLOC_SIZE
CONFIG_SYS_SPL_MALLOC_START
We introduce a default value here as well, and CONFIG_SYS_SPL_MALLOC to
control if we have a malloc pool or not.
- Make all users of CUSTOM_SYS_INIT_SP_ADDR reference SYS_INIT_SP_ADDR
- Introduce HAS_CUSTOM_SYS_INIT_SP_ADDR to allow for setting the stack
pointer directly, otherwise we use the common calculation.
- On some platforms that were using the standard calculation but did not
set CONFIG_SYS_INIT_RAM_SIZE / CONFIG_SYS_INIT_RAM_ADDR, set them.
- On a small number of platforms that were not subtracting
GENERATED_GBL_DATA_SIZE do so now via the standard calculation.
- CONFIG_SYS_INIT_SP_OFFSET is now widely unused, so remove it from most
board config header files.
CONFIG_SYS_CBSIZE
CONFIG_SYS_PBSIZE
CONFIG_SYS_MAXARGS
Resync all defconfig files using moveconfig.py
Up till now the CONFIG_POWER_TPS65217 has been defined in several header
files for am335x SoC.
This patch renames it to CONFIG_PMIC_TPS65217, which better reflects the
role of this IC circuit.
Moreover, new CONFIG_PMIC_TPS65217 has been introduced in Kconfig
to be used with boards, which both support DM_PMIC and DM_I2C.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
[trini: Migrate all other platforms as well]
CONFIG_NET_RETRY_COUNT
Cc: Ramon Fried <rfried.dev@gmail.com>
CONFIG_BOOTP_MAY_FAIL
CONFIG_BOOTP_VENDOREX
CONFIG_BOOTP_BOOTFILESIZE
CONFIG_BOOTP_NISDOMAIN
CONFIG_BOOTP_TIMEOFFSET
Rename these options so that CONFIG_IS_ENABLED can be used with them.
[trini: Fixup some incorrect renames]
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Now that we have consistent usage, migrate this symbol to Kconfig.
Rename this option so that CONFIG_IS_ENABLED can be used with it.
CONFIG_NETCONSOLE
CONFIG_SYS_MMC_ENV_DEV
CONFIG_SYS_MMC_ENV_PART
Note that with this conversion we now have consistent behavior with
respect to ensuring that we have always selected the correct MMC
device and hardware partition.
CONFIG_BOOTP_SEND_HOSTNAME
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Move this symbol to Kconfig. As part of this we can drop a UBI-specific
symbol that was a stop-gap for not having this particular symbol in
Kconfig.
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
Enable the extended ENV options for AT91 and OMAP2PLUS in order to be
able to use CONFIG_ENV_UBI_* on these architectures.
As this change also makes the configs ENV_SIZE, ENV_SECT_SIZE,
ENV_OFFSET visible to AT91 and OMAP2PLUS, migrate users of these to
KConfig.
This migration was run using an extended moveconfig.py which evaluates
expressions such as "(512 << 10)". See patch ("moveconfig: expand
simple expressions").
All modified boards were built with SOURCE_DATE_EPOCH=0 before and
after the change and successfully confirmed that the identical binary
is generated (the only exception was igep00x0, which does not define
CONFIG_ENV_IS_IN_UBI in the original board header. Once that is
defined, the test passes too).
hs: rebased patch to:
68b90e57bc: "configs: tinker-rk3288 disable CONFIG_SPL_I2C_SUPPORT"
Signed-off-by: Markus Klotzbuecher <markus.klotzbuecher@kistler.com>
Cc: Eugen Hristev <eugen.hristev@microchip.com>
USB_MUSB_TI requires USB_MUSB_DSPS, failing at link time if it's not
selected:
drivers/usb/musb-new/built-in.o: In function `ti_musb_host_ofdata_to_platdata':
drivers/usb/musb-new/ti-musb.c:193: undefined reference to `musb_dsps_ops'
or if OF_CONTROL is not selected:
arch/arm/mach-omap2/built-in.o:(.data.usb0+0x24): undefined reference to `musb_dsps_ops'
Reviewed-by: Hannes Schmelzer <oe5hpm@oevsv.at>
Tested-by: Hannes Schmelzer <oe5hpm@oevsv.at>
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
The commit 1bac199e8c87 ("configs: Resync with savedefconfig")
did remove ethernet driver from following boards defconfig:
- brppt1_mmc
- brppt1_nand
- brppt1_spi
With this commit we add ethernet and responsible phy support again.
Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
The TPS62517 PMIC driver has been partially converted to DM, so the
legacy I2C access layer isn't needed anymore.
