path: root/configs/boston64r2el_defconfig
2017-08-15env: Convert CONFIG_ENV_IS_IN... to a choiceSimon Glass
At present we support multiple environment drivers but there is not way to select between them at run time. Also settings related to the position and size of the environment area are global (i.e. apply to all locations). Until these limitations are removed we cannot really support more than one environment location. Adjust the location to be a choice so that only one can be selected. By default the environment is 'nowhere', meaning that the environment exists only in memory and cannot be saved. Also expand the help for the 'nowhere' option and move it to the top since it is the default. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Move all of the imply logic to default X if Y so it works again] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-12boston: Enable CONFIG_DISTRO_DEFAULTS in defconfigsPaul Burton
CONFIG_DISTRO_DEFAULTS selects a number of things we want for Boston defconfigs & generally describes what we want - to be able to boot an arbitrary Linux distribution. Enable it in order to shorten the defconfigs & to automatically keep up with any changes in the choice of Kconfig symbols selected. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-21boston: Introduce support for the MIPS Boston development boardPaul Burton
This patch introduces support for building U-Boot to run on the MIPS Boston development board. This is a board built around an FPGA & an Intel EG20T Platform Controller Hub, used largely as part of the development of new CPUs and their software support. It is essentially the successor to the older MIPS Malta board. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
