path: root/configs/boston32r6el_defconfig
2020-05-08treewide: mem: Move mtest related defines to KconfigAshok Reddy Soma
Move below defines which are used by mtest utility to Kconfig. CONFIG_SYS_MEMTEST_START CONFIG_SYS_MEMTEST_END Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fix kmcoge5ne board, re-run migration as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-12-04mtd: ensure MTD is compiled when there is a SPI NOR flash using MTDMiquel Raynal
MTD must be enabled when there is a SPI NOR flash using the SPI_FLASH_MTD config entry. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-12-03mtd: rename CONFIG_MTD -> CONFIG_DM_MTDMiquel Raynal
CONFIG_MTD must be reserved for the MTD core. Like any other subsystem, prefix the symbol by DM when it comes to DM support. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Add Kconfig files] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-01-16MIPS: boston: switch to CONFIG_OF_SEPARATEDaniel Schwierzeck
Fix the Kconfig warning to not use CONFIG_OF_EMBED in defconfigs. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-07-11MIPS: add MIPS Release 6 build coverage for Boston boardsDaniel Schwierzeck
Now that Travis CI is building with gcc-7.3.0, we can add build coverage for all combinations of MIPS Release 6 instruction sets (MIPS32, MIPS64, Big Endian, Little Endian). Add mew default configs for Boston board for all MIPS Release 6 variants. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
