path: root/configs/boston32r6el_defconfig
2019-01-16MIPS: boston: switch to CONFIG_OF_SEPARATEDaniel Schwierzeck
Fix the Kconfig warning to not use CONFIG_OF_EMBED in defconfigs. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-07-11MIPS: add MIPS Release 6 build coverage for Boston boardsDaniel Schwierzeck
Now that Travis CI is building with gcc-7.3.0, we can add build coverage for all combinations of MIPS Release 6 instruction sets (MIPS32, MIPS64, Big Endian, Little Endian). Add mew default configs for Boston board for all MIPS Release 6 variants. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
