path: root/configs/bk4r1_defconfig
2017-08-07Move PHY_MICREL and PHY_MICREL_KSZ90X1 to KconfigAlexandru Gagniuc
2017-05-22Convert CONFIG_CMD_EEPROM et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_EEPROM CONFIG_CMD_EEPROM_LAYOUT CONFIG_EEPROM_LAYOUT_HELP_STRING Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Rework Kconfig logic slightly, define EEPROM location on TI eval platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-03-19Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: configs/bk4r1_defconfig configs/colibri_vf_defconfig configs/pcm052_defconfig include/configs/colibri_vf.h include/configs/pcm052.h
2017-03-19ARM: vf610: move to standard arch/board approachStefan Agner
Move Freescale/NXP Vybrid to a standard arch/board approach, similar to what has been done to i.MX 6 earlier in commit 89ebc82137be ("ARM: mx6: move to a standard arch/board approach"). Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-03-18arm: Migrate SYS_THUMB_BUILD to Kconfig, introduce SPL_SYS_THUMB_BUILDTom Rini
Today, we have cases where we wish to build all of U-Boot in Thumb2 mode for various reasons. We also have cases where we only build SPL in Thumb2 mode due to size constraints and wish to build the rest of the system in ARM mode. So in this migration we introduce a new symbol as well, SPL_SYS_THUMB_BUILD to control if we build everything or just SPL (or in theory, just U-Boot) in Thumb2 mode. Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
2016-10-06pcm052: add new BK4r1 target based on PCM052 SoMAlbert ARIBAUD \(3ADEV\)
Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
