path: root/configs/birdland_bav335a_defconfig
2015-04-18ARM: bav335x: use "select" instead of default value in defconfigMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-03-24bav335x: Update defconfigs and fix typo in EEPROM config formatGilles Gameiro
After v2015.01 we need to have DM enabled in order to use UART. Also fix a typo in the EEPROM config format. Signed-off-by: Gilles Gameiro <gilles@gigadevices.com> [trini: Reword commit message, re-save defconfigs with 'savedefconfig'] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-03-05Adding Support for BAV335x boardsGilles Gameiro
