path: root/configs/bg0900_defconfig
2015-07-01defconfig: Move CONFIG_SPI_FLASH_BAR from configsJagan Teki
This commit moves: - CONFIG_SPI_FLASH_BAR from include/configs/*.h into configs/*_defconfigs Signed-off-by: Jagan Teki <jteki@openedev.com>
