path: root/configs/bf538f-ezkit_defconfig
2015-11-04blackfin: Disable CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED in some casesTom Rini
The boards do not link for me due to exceeding their size constrains, change the config so they fit again. Cc: Sonic Zhang <sonic.adi@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2015-07-08blackfin: Fix build regression due to image sizeJoe Hershberger
bf533-stamp, bf538f-ezkit, and cm-bf548 are very space limited. This was introduced by: 6e0d26c0502e (net: Handle ethaddr changes as an env callback) by enabling CONFIG_REGEX, which is too big for these boards. This patch disables CONFIG_REGEX at the expense of working with more than the first ethaddr. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2015-06-11blackfin: fix undefined reference to srand and randMasahiro Yamada
Commit 9ba9e85f3f1c (net: Fix NET_RANDOM_ETHADDR dependencies) accidentally dropped CONFIG_LIB_RAND defines for 14 Blackfin boards. Prior to that commit, those boards defined CONFIG_LIB_RAND, but not CONFIG_NET_RANDOM_ETHADDR. So, commit 9ba9e85f3f1c should not have touched them, but in fact it ripped CONFIG_LIB_RAND off from all the header files, which caused undefined reference to srand and rand. CONFIG_LIB_RAND=y must be revived for such boards. BTW, this commit indeed makes it better, but even with this fix, three boards (bf533-stamp, bf538f-ezkit, cm-bf548) still can not build due to region 'ram' overflowed error. This was cause by commit 6eed3786c68c (net: Move the CMD_NET config to defconfigs) because CMD_NET selects NET, and NET selects REGEX. Eventually, some boards were newly enabled with CONFIG_REGEX, increasing the memory footprint. A patch is expected to fix the build error. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2014-09-24kconfig: move CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED to KconfigMasahiro Yamada
If this option is enabled, the objects under lib/ directory are compiled with speed optimization, not size optimization. (Currently, only used by some Blackfin boards.) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
