path: root/configs/bf527-ezkit_defconfig
2015-11-04blackfin: Disable CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED in some casesTom Rini
The boards do not link for me due to exceeding their size constrains, change the config so they fit again. Cc: Sonic Zhang <sonic.adi@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2015-10-28net: TFTP: variables cleanup and additionAlbert ARIBAUD \(3ADEV\)
TFTP source and destination port variable names are 'tftpsrcp' and 'tftpdstp' in the code, but 'tftpsrcport' and 'tftpdstport' in the README file. Fix the README. Add environment variable 'tftptimeoutcountmax'. As per the comments about the global variable tftp_timeout_count_max, make sure tftptimeoutcountmax is nonnegative. Introduce configuration option CONFIG_NET_TFTP_VARS, which controls whether environment variables tftpblocksize, tftptimeout, and tftptimoueoutcountmax are read by the TFTP client code. CONFIG_NET_TFTP_VARS defaults to y but can be set to n by targets with to tight size contraints. Make bf527-ezkit set CONFIG_NET_TFTP_VARS to n to keep the target size below limit.
2015-05-20net: Remove all calls to net_random_ethaddr()Joe Hershberger
Remove the calls to net_random_ethaddr() that some boards and some drivers are calling. This is now implemented inside of net/eth.c Enable the feature for all boards that previously enabled it. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-By: Michael Walle <michael@walle.cc> (for the lsxl board part) Series-changes: 2 -Fixed bfin build errors
2014-09-24kconfig: move CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED to KconfigMasahiro Yamada
If this option is enabled, the objects under lib/ directory are compiled with speed optimization, not size optimization. (Currently, only used by some Blackfin boards.) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
