The boards do not link for me due to exceeding their size constrains, change
the config so they fit again.
Cc: Sonic Zhang <sonic.adi@gmail.com>
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
them from include/configs.
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
Commit 9ba9e85f3f1c (net: Fix NET_RANDOM_ETHADDR dependencies)
accidentally dropped CONFIG_LIB_RAND defines for 14 Blackfin boards.
Prior to that commit, those boards defined CONFIG_LIB_RAND, but not
CONFIG_NET_RANDOM_ETHADDR. So, commit 9ba9e85f3f1c should not have
touched them, but in fact it ripped CONFIG_LIB_RAND off from all the
header files, which caused undefined reference to srand and rand.
CONFIG_LIB_RAND=y must be revived for such boards.
BTW, this commit indeed makes it better, but even with this fix,
three boards (bf533-stamp, bf538f-ezkit, cm-bf548) still can not
build due to region 'ram' overflowed error. This was cause by
commit 6eed3786c68c (net: Move the CMD_NET config to defconfigs)
because CMD_NET selects NET, and NET selects REGEX. Eventually,
some boards were newly enabled with CONFIG_REGEX, increasing the
memory footprint. A patch is expected to fix the build error.
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
In order to reduce merge conflicts and to maintain the simplest possible
defconfig files, we should be using the savedefconfig feature of Kconfig
every time a new feature is added. This keeps the defconfig settings to
a minimum (only those things not default) and keeps them in the same
order as the Kconfig options.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
If this option is enabled, the objects under lib/ directory
are compiled with speed optimization, not size optimization.
(Currently, only used by some Blackfin boards.)
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
