path: root/configs/bf526-ezbrd_defconfig
2016-06-04configs: blackfin: move CONFIG_USB to defconfigMasahiro Yamada
These Blackfin boards are the last ones that define CONFIG_USB in their headers. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-11-04blackfin: Disable CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED in some casesTom Rini
The boards do not link for me due to exceeding their size constrains, change the config so they fit again. Cc: Sonic Zhang <sonic.adi@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2015-05-20net: Remove all calls to net_random_ethaddr()Joe Hershberger
Remove the calls to net_random_ethaddr() that some boards and some drivers are calling. This is now implemented inside of net/eth.c Enable the feature for all boards that previously enabled it. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-By: Michael Walle <michael@walle.cc> (for the lsxl board part) Series-changes: 2 -Fixed bfin build errors
2014-09-24kconfig: move CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED to KconfigMasahiro Yamada
If this option is enabled, the objects under lib/ directory are compiled with speed optimization, not size optimization. (Currently, only used by some Blackfin boards.) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
