path: root/configs/bf518f-ezbrd_defconfig
2015-05-20net: Remove all calls to net_random_ethaddr()Joe Hershberger
Remove the calls to net_random_ethaddr() that some boards and some drivers are calling. This is now implemented inside of net/eth.c Enable the feature for all boards that previously enabled it. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-By: Michael Walle <michael@walle.cc> (for the lsxl board part) Series-changes: 2 -Fixed bfin build errors
2014-09-24kconfig: move CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED to KconfigMasahiro Yamada
If this option is enabled, the objects under lib/ directory are compiled with speed optimization, not size optimization. (Currently, only used by some Blackfin boards.) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
