path: root/configs/bf506f-ezkit_defconfig
2014-09-24kconfig: move CONFIG_CMD_IMPORTENV to KconfigMasahiro Yamada
Since CONFIG_CMD_IMPORTENV is defined in config_cmd_defaults.h, it should be enabled for all the boards except bf506f-ezkit that undefs it explicitely. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-09-24kconfig: move CONFIG_CMD_EXPORTENV to KconfigMasahiro Yamada
Since CONFIG_CMD_EXPORTENV is defined in config_cmd_defaults.h, it should be enabled for all the boards except bf506f-ezkit that undefs it explicitely. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-09-24kconfig: move CONFIG_CMD_BOOTM to KconfigMasahiro Yamada
CONFIG_CMD_BOOTM is defined in config_cmd_defaults.h which is forcebly included from each board. So, the default value of "config CMD_BOOTM" should be "y". For some boards undefining it (bf506f-ezkit, controlcenterd_TRAILBLA, controlcenterd_TRAILBLAZER_DEVELOP, controlcenterd_TRAILBLAZER), "# CONFIG_CMD_BOOTM is not set" should be added to their defconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
