path: root/configs/beaver_defconfig
2020-08-10configs: Resync with savedefconfigTom Rini
2020-08-08Convert CONFIG_SYS_MMC_ENV_DEV et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_MMC_ENV_DEV CONFIG_SYS_MMC_ENV_PART Note that with this conversion we now have consistent behavior with respect to ensuring that we have always selected the correct MMC device and hardware partition. Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-28Convert CONFIG_ENV_OVERWRITE to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ENV_OVERWRITE Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rerun migration, remove some comments] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-28configs: Resync with savedefconfigTom Rini
2020-07-06configs: Resync with savedefconfigTom Rini
2020-05-15rename symbol: CONFIG_TEGRA -> CONFIG_ARCH_TEGRATrevor Woerner
Have this symbol follow the pattern of all other such symbols. Signed-off-by: Trevor Woerner <twoerner@gmail.com>
2019-12-04configs: Resync with savedefconfigTom Rini
2019-11-07configs: Resync with savedefconfigTom Rini
2019-09-23configs: Resync with savedefconfigTom Rini
2019-02-22configs: Resync with savedefconfigTom Rini
2019-02-20Kconfig: tegra: Migrate USB_EHCI_TEGRAPeter Robinson
Migrate USB_EHCI_TEGRA from headers to Kconfig Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Marek Vasut <marex@denx.de> Cc: Marcel Ziswiler <marcel.ziswiler@toradex.com> Cc: Peter.Chubb@data61.csiro.au Cc: Lucas Stach <dev@lynxeye.de> Cc: Stefan Agner <stefan.agner@toradex.com> Cc: Alban Bedel <alban.bedel@avionic-design.de> Cc: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2019-02-20Kconfig: tegra: Migrate SYS_I2C_TEGRAPeter Robinson
Migrate SYS_I2C_TEGRA from headers to Kconfig Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Heiko Schocher <hs@denx.de> Cc: Marcel Ziswiler <marcel.ziswiler@toradex.com> Cc: Peter.Chubb@data61.csiro.au Cc: Lucas Stach <dev@lynxeye.de> Cc: Stefan Agner <stefan.agner@toradex.com> Cc: Alban Bedel <alban.bedel@avionic-design.de> Cc: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-04-16part: Disable CONFIG_SPL_ISO_PARTITION by defaultAlexander Graf
We enabled CONFIG_ISO_PARTITION by default for distro boot, so that U-Boot could load distro images that usually get shipped as iso images. These images usually come with a board agnostic boot environment. However, there is very little point in having ISO support enabled (for anyone really) in SPL, as the whole idea of SPL is to load U-Boot proper which again is board specific. So the fact that we enable ISO support in U-Boot proper does not mean at all that we want ISO support in U-Boot SPL. Hence, let's remove the Kconfig dependency. Along the way, let's also clean up all those default configs that disabled SPL ISO support. Signed-off-by: Alexander Graf <agraf@suse.de>
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28dm: tegra: Move nyan-big, jetson-tk1/tx1, beaver to livetreeSimon Glass
Change these board to use a live device tree after relocation. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Tested-on: Beaver, Jetson-TK1 Tested-by: Stephen Warren <swarren@nvidia.com>
2017-06-01tegra: Convert MMC to use driver model for operationsSimon Glass
Enable CONFIG_DM_MMC_OPS and CONFIG_BLK for all Tegra devices. This moves Tegra to use driver model fully for MMC. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-12-03Enable DISTRO_DEFAULT on platforms that missed it beforeTom Rini
A number of platforms had been using the distro default feature before it was moved to Kconfig but did not enable the new Kconfig option when it was enabled. This caused a regression in terms of features and this introduces breakage when more things move to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_SYS_STDIO_DEREGISTER to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_STDIO_DEREGISTER This option should never be enabled in SPL, so use CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Re-sync] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-11dm: mmc: Enable DM_MMC_OPS by default with DM_MMCSimon Glass
These two options go together and it is best to do the conversion in one step. So enable DM_MMC_OPS by default if DM_MMC is enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-11dm: blk: Enable CONFIG_BLK if DM_MMC is enabledSimon Glass
To speed up conversion to CONFIG_BLK, enable it by default when DM_MMC is enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
