path: root/configs/bct-brettl2_defconfig
2015-06-01blackfin: fix build error on bct-brettl2 boardMasahiro Yamada
Commit 76ec988b062e (net: Remove all calls to net_random_ethaddr()) accidentally deleted CONFIG_TARGET_BCT_BRETTL2=y, and since then bct-brettl2 would not build. Since commit a26cd04920dc (arch: Make board selection choices optional), Kconfig actually allows such a .config file in which no board is selected, but the build never succeeds. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-05-20net: Remove all calls to net_random_ethaddr()Joe Hershberger
Remove the calls to net_random_ethaddr() that some boards and some drivers are calling. This is now implemented inside of net/eth.c Enable the feature for all boards that previously enabled it. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-By: Michael Walle <michael@walle.cc> (for the lsxl board part) Series-changes: 2 -Fixed bfin build errors
2014-09-24kconfig: move CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED to KconfigMasahiro Yamada
If this option is enabled, the objects under lib/ directory are compiled with speed optimization, not size optimization. (Currently, only used by some Blackfin boards.) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
