The current name is inconsistent with SPL which uses CONFIG_SPL_TEXT_BASE
and this makes it imposible to use CONFIG_VAL().
Rename it to resolve this problem.
BCM6856 is a Broadcom B53 based PON Gateway SoC. It is part of the BCA
(Broadband Carrier Access origin) chipset family. Like other Broadband
SoC, this patch adds it under CONFIG_BCM6856 chip config and
CONFIG_ARCH_BCMBCA platform config.
This initial support includes a bare-bone implementation and dts with
CPU subsystem, memory and Broadcom uart. This SoC is supported in the
linux-next git repository so the dts and dtsi files are copied from
linux.
The u-boot image can be loaded from flash or network to the entry point
address in the memory and boot from there to the console.
Signed-off-by: William Zhang <william.zhang@broadcom.com>
Reviewed-by: Philippe Reynes <philippe.reynes@softathome.com>
