path: root/configs/bcm963158_ram_defconfig
2020-07-28configs: Resync with savedefconfigTom Rini
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-12-03mtd: rename CONFIG_MTD -> CONFIG_DM_MTDMiquel Raynal
CONFIG_MTD must be reserved for the MTD core. Like any other subsystem, prefix the symbol by DM when it comes to DM support. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Add Kconfig files] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-12-03mtd: rename CONFIG_NAND -> CONFIG_MTD_RAW_NANDMiquel Raynal
Add more clarity by changing the Kconfig entry name. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> [trini: Re-run migration, update a few more cases] Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-11-07configs: Resync with savedefconfigTom Rini
2019-10-11configs: Add hsspi/spi support to bcm963158.Kursad Oney
This commit enable the support of the spi-nor for the broadcom reference board bcm963158. Signed-off-by: Kursad Oney <kursad.oney@broadcom.com> Reviewed-by: Philippe Reynes <philippe.reynes@softathome.com>
2019-09-23configs: Resync with savedefconfigTom Rini
2019-08-25configs: Resync with savedefconfigTom Rini
2019-07-11configs: Rename CONFIG_IMAGE_FORMAT_LEGACY to CONFIG_LEGACY_IMAGE_FORMATTom Rini
The name CONFIG_LEGACY_IMAGE_FORMAT reads slightly better along with allowing us to avoid a rather nasty Kbuild/Kconfig issue down the line with CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY). In a few places outside of cmd/ switch to using CONFIG_IS_ENABLED() to test what is set. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-18configs: bcm963158 disable CONFIG_CMD_BOOTEFI_SELFTESTHeinrich Schuchardt
Configuration option CONFIG_CMD_BOOTEFI_SELFTEST is useful for the development of the UEFI sub-system. For production it is not needed. Remove CONFIG_CMD_BOOTEFI_SELFTEST from bcm963158_ram_defconfig. Suggested-by: Tom Rini <trini@konsulko.com> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-04-23bcm963158: enable led supportPhilippe Reynes
Enable the led support in the configuration of the board bcm963158. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2019-04-22bcm963158: add nand supportPhilippe Reynes
Enable the nand support (driver and command) in the configuration of the board bcm963158. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2019-04-12bcm963158: enable gpio supportPhilippe Reynes
Enable the gpio support (driver and command) in the configuration of the board bcm963158. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2019-02-22configs: Resync with savedefconfigTom Rini
2019-02-09bcm963158: enable watchdog and reboot with watchdogPhilippe Reynes
Enable watchdog and reboot with watchdog in the configuration. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2019-02-09bcm963158: add initial supportPhilippe Reynes
This add the initial support of the broadcom reference board bcm963158 with a bcm63158 SoC. This board has 1 GB of ram, 512 MB of flash (nand), 2 usb port, 1 uart, 4 ethernet ports (LAN), 1 ethernet port (WAN). Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
