path: root/configs/bcm958712k_defconfig
2018-03-16Convert all of CONFIG_CONS_INDEX to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX We have existing entries for this option in a number of places, with different guards on them. They're also sometimes used for things not directly inside of the serial driver. First, introduce a new symbol to guard the use of CONFIG_CONS_INDEX, so that in the case where we don't need this for the serial driver, but for some other use, we can still do it. Next, consolidate all of these into the single entry in drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that we can imply a correct value here to make the defconfig side of this smaller. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rework a lot of the logic here, such that I took authorship from Adam, but kept his S-o-B line] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-03-20board: ns2: Add support for Broadcom Northstar 2Jon Mason
Add support for the Broadcom Northstar2 SoC and SVK (bcm958712k). The BCM5871X is a series of quad-core 64-bit 2GHz ARMv8 Cortex-A57 processors targeting a broad range of networking applications. Signed-off-by: Jon Mason <jon.mason@broadcom.com>
