path: root/configs/bcm958300k_defconfig
2014-11-23ARM: bcm: Enable five Cygnus boardsSteve Rae
bcm911360_entphn bcm911360_entphn-ns bcm911360k bcm958300k-ns bcm958305k - updates to support Cygnus and NSP board families better - add functions so CONFIG_ARMV7_NONSEC can be enabled on Cygnus boards Signed-off-by: Steve Rae <srae@broadcom.com>
2014-08-30arm: convert Cygnus and NSP boards to KconfigSteve Rae
Convert the bcm958300k and the bcm958622hr boards from "boards.cfg" to Kconfig. Signed-off-by: Steve Rae <srae@broadcom.com>
