path: root/configs/bcm911360_entphn_defconfig
2017-08-11configs: Resync with savedefconfigTom Rini
2017-05-22lib: move hash CONFIG options to KconfigTom Rini
Commit 94e3c8c4fd7b ("crypto/fsl - Add progressive hashing support using hardware acceleration.") created entries for CONFIG_SHA1, CONFIG_SHA256, CONFIG_SHA_HW_ACCEL, and CONFIG_SHA_PROG_HW_ACCEL. However, no defconfig has migrated to it. Complete the move by first adding additional logic to various Kconfig files to select this when required and then use the moveconfig tool. In many cases we can select these because they are required to implement other drivers. We also correct how we include the various hashing algorithms in SPL. This commit was generated as follows (after Kconfig additions): [1] tools/moveconfig.py -y SHA1 SHA256 SHA_HW_ACCEL [2] tools/moveconfig.py -y SHA_PROG_HW_ACCEL Note: We cannot move SHA_HW_ACCEL and SHA_PROG_HW_ACCEL simultaneously because there is dependency between them. Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com> Cc: Naveen Burmi <NaveenBurmi@freescale.com> Cc: Po Liu <po.liu@freescale.com> Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com> Cc: Priyanka Jain <Priyanka.Jain@freescale.com> Cc: Shaohui Xie <Shaohui.Xie@freescale.com> Cc: Chunhe Lan <Chunhe.Lan@freescale.com> Cc: Chander Kashyap <k.chander@samsung.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Feng Li <feng.li_2@nxp.com> Cc: Alison Wang <alison.wang@freescale.com> Cc: Sumit Garg <sumit.garg@nxp.com> Cc: Mingkai Hu <Mingkai.Hu@freescale.com> Cc: York Sun <york.sun@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Heiko Schocher <hs@denx.de> Cc: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-06-20autoboot: add CONFIG_AUTOBOOT to allow to not compile autoboot.cMasahiro Yamada
Since commit bb597c0eeb7e ("common: bootdelay: move CONFIG_BOOTDELAY into a Kconfig option"), CONFIG_BOOTDELAY is defined for all boards. Prior to that commit, it was allowed to unset CONFIG_BOOTDELAY to not compile common/autoboot.c, as described in common/Makefile: # This option is not just y/n - it can have a numeric value ifdef CONFIG_BOOTDELAY obj-y += autoboot.o endif It was a bit odd to enable/disable code with an integer type option, but it was how this option worked before that commit, and several boards actually unset it to opt out of the autoboot feature. This commit adds a new bool option, CONFIG_AUTOBOOT, and makes CONFIG_BOOTDELAY depend on it. I chose "default y" for this option because most boards use the autoboot. I added "# CONFIG_AUTOBOOT is not set" for the boards that had not set CONFIG_BOOTDELAY prior to the bad commit. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2014-11-23ARM: bcm: Enable five Cygnus boardsSteve Rae
bcm911360_entphn bcm911360_entphn-ns bcm911360k bcm958300k-ns bcm958305k - updates to support Cygnus and NSP board families better - add functions so CONFIG_ARMV7_NONSEC can be enabled on Cygnus boards Signed-off-by: Steve Rae <srae@broadcom.com>
