CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
CONFIG_PHYLIB
CONFIG_BITBANGMII
CONFIG_MV88E6352_SWITCH
CONFIG_MV88E61XX_SWITCH
CONFIG_PHYLIB_10G
CONFIG_PHY_AQUANTIA
CONFIG_PHY_ATHEROS
CONFIG_PHY_BROADCOM
CONFIG_PHY_CORTINA
CONFIG_PHY_DAVICOM
CONFIG_PHY_ET1011C
CONFIG_PHY_LXT
CONFIG_PHY_MARVELL
CONFIG_PHY_MICREL
CONFIG_PHY_NATSEMI
CONFIG_PHY_REALTEK
CONFIG_RTL8211X_PHY_FORCE_MASTER
CONFIG_PHY_SMSC
CONFIG_PHY_TERANETICS
CONFIG_PHY_TI
CONFIG_PHY_VITESSE
CONFIG_PHY_XILINX
Both CMD_MX_CYCLIC and MX_CYCLIC are in use and defined in Kconfig,
but only the non-CMD version currently does anything. This changes all
usages to prefer the CMD_MX_CYCLIC option (since it's only affecting
addition of the commands), and switches defconfigs using the non-CMD
version to use the CMD version.
Signed-off-by: Joel Johnson <mrjoel@lixil.net>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_MX_CYCLIC
Acked-by: David Lechner <david@lechnology.com>
The bounce buffer is used by a few drivers (most of the MMC drivers)
to overcome limitations in their respective DMA implementation.
This moves the configuration to Kconfig and makes it user-selectable
(even though it will be a required feature to make those drivers
work): the expected usage is for drivers depending on this to 'select'
it unconditionally from their respective Kconfig (see follow-up
patches).
This commit includes a full migration using moveconfig.py to ensure
that each commit compiles. To ensure bisectability we update
dependencies of various drivers to now select BOUNCE_BUFFER when needed.
[trini: Squash all patches to ensure bisectability]
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion]
Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion]
Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
CONFIG_CONS_INDEX
We have existing entries for this option in a number of places, with
different guards on them. They're also sometimes used for things not
directly inside of the serial driver. First, introduce a new symbol to
guard the use of CONFIG_CONS_INDEX, so that in the case where we don't
need this for the serial driver, but for some other use, we can still do
it. Next, consolidate all of these into the single entry in
drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that
we can imply a correct value here to make the defconfig side of this
smaller.
[trini: Rework a lot of the logic here, such that I took authorship from
Adam, but kept his S-o-B line]
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
Commit 94e3c8c4fd7b ("crypto/fsl - Add progressive hashing support
using hardware acceleration.") created entries for CONFIG_SHA1,
CONFIG_SHA256, CONFIG_SHA_HW_ACCEL, and CONFIG_SHA_PROG_HW_ACCEL.
However, no defconfig has migrated to it. Complete the move by first
adding additional logic to various Kconfig files to select this when
required and then use the moveconfig tool. In many cases we can select
these because they are required to implement other drivers. We also
correct how we include the various hashing algorithms in SPL.
This commit was generated as follows (after Kconfig additions):
[1] tools/moveconfig.py -y SHA1 SHA256 SHA_HW_ACCEL
[2] tools/moveconfig.py -y SHA_PROG_HW_ACCEL
Note:
We cannot move SHA_HW_ACCEL and SHA_PROG_HW_ACCEL simultaneously
because there is dependency between them.
Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Cc: Naveen Burmi <NaveenBurmi@freescale.com>
Cc: Po Liu <po.liu@freescale.com>
Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Cc: Priyanka Jain <Priyanka.Jain@freescale.com>
Cc: Shaohui Xie <Shaohui.Xie@freescale.com>
Cc: Chunhe Lan <Chunhe.Lan@freescale.com>
Cc: Chander Kashyap <k.chander@samsung.com>
Cc: Steve Rae <steve.rae@raedomain.com>
Cc: Dirk Eibach <eibach@gdsys.de>
Cc: Feng Li <feng.li_2@nxp.com>
Cc: Alison Wang <alison.wang@freescale.com>
Cc: Sumit Garg <sumit.garg@nxp.com>
Cc: Mingkai Hu <Mingkai.Hu@freescale.com>
Cc: York Sun <york.sun@nxp.com>
Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Cc: Akshay Saraswat <akshay.s@samsung.com>
Cc: Jagan Teki <jagan@amarulasolutions.com>
Commit 7a777f6d6f35 ("mmc: Add generic Kconfig option") created
a Kconfig entry for this option without any actual moves, then
commit 44c798799f66 ("sunxi: Use Kconfig CONFIG_MMC") moved
instances only for SUNXI.
We generally do not like such partial moves. This kind of work
is automated by tools/moveconfig.py, so it is pretty easy to
complete this move.
I am adding "default ARM || PPC || SANDBOX" (suggested by Tom).
This shortens the configs and will ease new board porting.
This commit was created as follows:
[1] Edit Kconfig (remove the "depends on", add the "default",
copy the prompt and help message from Linux)
[2] Run 'tools/moveconfig.py -y -s -r HEAD MMC'
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
Create a Kconfig entry for DISPLAY_CPUINFO and make it be the default
move VERSION_VARIABLE from board config file into a
Kconfig option.
Since commit bb597c0eeb7e ("common: bootdelay: move CONFIG_BOOTDELAY
into a Kconfig option"), CONFIG_BOOTDELAY is defined for all boards.
Prior to that commit, it was allowed to unset CONFIG_BOOTDELAY to
not compile common/autoboot.c, as described in common/Makefile:
# This option is not just y/n - it can have a numeric value
ifdef CONFIG_BOOTDELAY
obj-y += autoboot.o
endif
It was a bit odd to enable/disable code with an integer type option,
but it was how this option worked before that commit, and several
boards actually unset it to opt out of the autoboot feature.
This commit adds a new bool option, CONFIG_AUTOBOOT, and makes
CONFIG_BOOTDELAY depend on it.
I chose "default y" for this option because most boards use the
autoboot. I added "# CONFIG_AUTOBOOT is not set" for the boards that
had not set CONFIG_BOOTDELAY prior to the bad commit.
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
them from include/configs.
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
In order to reduce merge conflicts and to maintain the simplest possible
defconfig files, we should be using the savedefconfig feature of Kconfig
every time a new feature is added. This keeps the defconfig settings to
a minimum (only those things not default) and keeps them in the same
order as the Kconfig options.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
bcm911360_entphn
bcm911360_entphn-ns
bcm911360k
bcm958300k-ns
bcm958305k
- updates to support Cygnus and NSP board families better
- add functions so CONFIG_ARMV7_NONSEC can be enabled on Cygnus boards
Signed-off-by: Steve Rae <srae@broadcom.com>
