path: root/configs/bcm7445_defconfig
2019-05-28dm: arm: bcmstb: Enable driver model MMC supportThomas Fitzsimmons
For bcm7445 and bcm7260, this patch enables CONFIG_DM_MMC and updates the bcmstb SDHCI driver to use the new driver model. This allows removal of SDHCI configuration handling from bcmstb.c, and eliminates a board removal compile warning. Signed-off-by: Thomas Fitzsimmons <fitzsim@fitzsim.org> Reviewed-by: Stefan Roese <sr@denx.de>
2019-03-25bcm7445: move some configuration in defconfig filePatrick Delaunay
Move some configurations in defconfig file - CONFIG_DM_SPI (removed by syncing defconfigs ) - CONFIG_CMD_SF - CONFIG_CMD_SPI - CONFIG_CMD_SF_TEST This allow correct dependency handling in Kconfig. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-11-13configs: Resync with savedefconfigTom Rini
2018-09-10arm: bcm7445: Change serial console indexThomas Fitzsimmons
Change the configured serial console index to reflect that it is the first physical UART, reorder some defconfig lines and move some environment configuration from bcmstb.h to bcm7445.h. Signed-off-by: Thomas Fitzsimmons <fitzsim@fitzsim.org> Cc: Florian Fainelli <f.fainelli@gmail.com>
2018-08-07configs: Resync with savedefconfigTom Rini
2018-07-10board: arm: Add support for Broadcom BCM7445Thomas Fitzsimmons
Add support for loading U-Boot on the Broadcom 7445 SoC. This port assumes Broadcom's BOLT bootloader is acting as the second stage bootloader, and U-Boot is acting as the third stage bootloader, loaded as an ELF program by BOLT. Signed-off-by: Thomas Fitzsimmons <fitzsim@fitzsim.org> Cc: Stefan Roese <sr@denx.de> Cc: Tom Rini <trini@konsulko.com> Cc: Florian Fainelli <f.fainelli@gmail.com>
