path: root/configs/bcm28155_ap_defconfig
2016-08-20fastboot: move to KconfigSteve Rae
- move bcm23550_w1d to Kconfig - move bcm28155_ap to Kconfig Signed-off-by: Steve Rae <steve.rae@raedomain.com>
2016-06-20autoboot: add CONFIG_AUTOBOOT to allow to not compile autoboot.cMasahiro Yamada
Since commit bb597c0eeb7e ("common: bootdelay: move CONFIG_BOOTDELAY into a Kconfig option"), CONFIG_BOOTDELAY is defined for all boards. Prior to that commit, it was allowed to unset CONFIG_BOOTDELAY to not compile common/autoboot.c, as described in common/Makefile: # This option is not just y/n - it can have a numeric value ifdef CONFIG_BOOTDELAY obj-y += autoboot.o endif It was a bit odd to enable/disable code with an integer type option, but it was how this option worked before that commit, and several boards actually unset it to opt out of the autoboot feature. This commit adds a new bool option, CONFIG_AUTOBOOT, and makes CONFIG_BOOTDELAY depend on it. I chose "default y" for this option because most boards use the autoboot. I added "# CONFIG_AUTOBOOT is not set" for the boards that had not set CONFIG_BOOTDELAY prior to the bad commit. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-13arm: bcm281xx: choose 8-bit phy bus widthSteve Rae
The Kona PHY supports an 8-bit wide UTMI interface, therefore, choose this Kconfig setting. Signed-off-by: Steve Rae <srae@broadcom.com>
2016-06-06arm/arm64: implement a boot header capabilityAndre Przywara
Some SPL loaders (like Allwinner's boot0, and Broadcom's boot0) require a header before the actual U-Boot binary to both check its validity and to find other data to load. Sometimes this header may only be a few bytes of information, and sometimes this might simply be space that needs to be reserved for a post-processing tool. Introduce a config option to allow assembler preprocessor commands to be inserted into the code at the appropriate location; typical assembler preprocessor commands might be: .space 1000 .word 0x12345678 Signed-off-by: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Steve Rae <srae@broadcom.com> Commit Notes: Please note that the current code: start.S (arm64) and vectors.S (arm) already jumps over some portion of data already, so this option basically just increases the size of this region (and the resulting binary). For use with Allwinner's boot0 blob there is a tool called boot0img[1], which fills the header to allow booting A64 based boards. For the Pine64 we need a 1536 byte header (including the branch instruction) at the moment, so we add this to the defconfig. [1] https://github.com/apritzel/pine64/tree/master/tools END Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-20Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
Conflicts: configs/bcm28155_ap_defconfig configs/dra72_evm_defconfig configs/dra74_evm_defconfig configs/ma5d4evk_defconfig Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-18bcm281xx: enable CONFIG_OF_LIBFDTSteve Rae
set the Kconfig parameter: CONFIG_OF_LIBFDT Signed-off-by: Steve Rae <srae@broadcom.com>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
