path: root/configs/bayleybay_defconfig
2018-04-16x86: Change default FRAMEBUFFER_VESA_MODE of some boardsBin Meng
This changes some boards' default FRAMEBUFFER_VESA_MODE to use 32-bit pixel format for better VxWorks compatibility. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Migrate CONFIG_LAST_STAGE_INIT to KconfigMario Six
Migrate the CONFIG_LAST_STAGE_INIT option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2017-08-24x86: bayleybay: Adjust VGA rom addressBin Meng
Adjust VGA rom address to 0xfffb0000 so that u-boot.rom image can be built again. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-08-24x86: kconfig: Imply CMD_PCIBin Meng
Let's imply the 'pci' command to access the de facto interconnect bus in an x86 system. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-08-01x86: kconfig: Let board select SPI flashBin Meng
Only a specific type of SPI flash exists on a board, having board Kconfig to select the SPI flash seems to make more sense. Other flash types are not necessary except coreboot, which implies all available flash drivers there. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: baytrail: kconfig: Imply platform specific driversBin Meng
BayTrail integrates lots of peripherals that have U-Boot drivers. Imply those in the platform Kconfig. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Imply DM uclass driversBin Meng
Now that all x86 boards have been converted to use DM, we can imply these uclass drivers (DM_ETH, DM_RTC, DM_USB, DM_VIDEO) from the top level. Previously DM_GPIO, DM_KEYBOARD, DM_SERIAL, DM_SPI, DM_SPI_FLASH are selected. Change to use 'imply' to allow them to be removed. Note with this change, chromebook_link64 build fails: common/built-in.o:(.data.env_htab+0xc): undefined reference to 'env_flags_validate' lib/built-in.o: In function `hsearch_r': lib/hashtable.c:380: undefined reference to 'env_callback_init' lib/hashtable.c:382: undefined reference to 'env_flags_init' make[1]: *** [spl/u-boot-spl] Error 1 CONFIG_SPL_ENV_SUPPORT is required for chromebook_link64 to build again. This is just a workaround as it is not needed at all. See commit bda40d5 "x86: qemu: Add a config for 64-bit U-Boot" for the same issue seen on QEMU 64-bit target. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Select OF_CONTROLBin Meng
This is a must have for all x86 boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Imply ENABLE_MRC_CACHE in the platform KconfigBin Meng
Platform knows whether MRC cache is implemented, but using it can be a choice of a specific board. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Select ARCH_EARLY_INIT_R in the platform KconfigBin Meng
This is architecture-dependent early initialization hence should be put in the platform Kconfig. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Select ARCH_MISC_INIT in the platform KconfigBin Meng
arch_misc_init() is intended to do architecture-dependent stuff. This is required by each platform. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Let board select BOARD_EARLY_INIT_FBin Meng
CONFIG_BOARD_EARLY_INIT_F literally indicates board-specific codes and should be not 'default y' for all x86 boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Imply HAVE_INTEL_ME in the platform KconfigBin Meng
Intel Management Engine is required by the platform, however it's not a must have when building a U-Boot image. For example, during development normally programming ME firmware is a one-time effort. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Select PCI and DM_PCIBin Meng
PCI is the de facto interconnect bus in an x86 system. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Select USE_PRIVATE_LIBGCCBin Meng
x86 is using the built-in libgcc implementation and this cannot be turned off. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Select TIMER and X86_TSC_TIMERBin Meng
Without a timer, U-Boot just doesn't boot. This is not something we can turn off. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-31configs: Resync with savedefconfigTom Rini
2017-07-30arch/x86: Select USB before selecting host driverAndy Shevchenko
Kbuild complains if USB is not selected before any of host driver. warning: (X86) selects USB_EHCI_HCD which has unmet direct dependencies (USB) warning: (X86) selects USB_EHCI_HCD which has unmet direct dependencies (USB) Select it for X86. Fixes: 64d6ac5bc4a9 ("Kconfig: USB: Migrate CONFIG_USB_EHCI_HCD users to Kconfig") Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> [bmeng: Update all x86 boards' defconfig files to remove CONFIG_USB] Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11Convert CONFIG_SCSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SCSI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-03-21mmc: pci: Add CONFIG_MMC_PCIFelipe Balbi
We don't want pci_mmc to compile every time x86 compiles, only when there's a platform that needs it. For that reason, we're adding a new CONFIG_MMC_PCI which platforms can choose to enable. Suggested-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-01-28disk: convert CONFIG_MAC_PARTITION to KconfigPatrick Delaunay
2017-01-25Convert CONFIG_ARCH_MISC_INIT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ARCH_MISC_INIT Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-25Convert CONFIG_ARCH_EARLY_INIT_R to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ARCH_EARLY_INIT_R Signed-off-by: Simon Glass <sjg@chromium.org>
2016-12-29mmc: move some SDHCI related options to KconfigMasahiro Yamada
While I moved the options, I also renamed them so that they are all prefixed with MMC_SDHCI_. This commit was created in the following steps. [1] Rename with the following command find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_MMC_SDMA/CONFIG_MMC_SDHCI_SDMA/g s/CONFIG_BCM2835_SDHCI/CONFIG_MMC_SDHCI_BCM2835/g s/CONFIG_KONA_SDHCI/CONFIG_MMC_SDHCI_KONA/g s/CONFIG_MV_SDHCI/CONFIG_MMC_SDHCI_MV/g s/CONFIG_S5P_SDHCI/CONFIG_MMC_SDHCI_S5P/g s/CONFIG_SPEAR_SDHCI/CONFIG_MMC_SDHCI_SPEAR/g ' [2] create the Kconfig entries in drivers/mmc/Kconfig [3] Move the options by the following command tools/moveconfig.py -y MMC_SDHCI_SDMA MMC_SDHCI_BCM2835 \ MMC_SDHCI_KONA MMC_SDHCI_MV MMC_SDHCI_S5P MMC_SDHCI_SPEAR [4] Sort drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-29mmc: move CONFIG_SDHCI to Kconfig, renaming to CONFIG_MMC_SDHCIMasahiro Yamada
Move CONFIG_SDHCI to Kconfig and rename it to CONFIG_MMC_SDHCI. My motivation for the rename is, ultimately, to make all the MMC options prefixed with MMC_ and SDHCI options with MMC_SDHCI_, like Linux. This commit was created as follows: [1] Rename the config option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_SDHCI/CONFIG_MMC_SDHCI/g' [2] create the entry for MMC_SDHCI in drivers/mmc/Kconfig [3] run "tools/moveconfig.py -y MMC_SDHCI" [4] add "depends on MMC_SDHCI" to existing SDHCI driver entries Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-10-23Convert CONFIG_USB_KEYBOARD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USB_KEYBOARD Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Fixup MPC86* configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_CONSOLE_SCROLL_LINES to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CONSOLE_SCROLL_LINES Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VGA_AS_SINGLE_DEVICE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VGA_AS_SINGLE_DEVICE Once we migrate to driver model for video, we should be able to drop this option. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-12x86: Convert to use DM VESA video driverBin Meng
At present only chromebook boards are converted to DM video. Other x86 boards are still using the legacy cfb_console driver. This switches to use DM version drivers. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
