path: root/configs/bananapi_m64_defconfig
2018-03-14sunxi: move CONFIG_SYS_TEXT_BASE out of defconfigsAndre Przywara
Commit 278b90ce786f ("configs: Migrate CONFIG_SYS_TEXT_BASE") made CONFIG_SYS_TEXT_BASE a proper Kconfig variable, with the consequence of moving the common definition shared by almost every sunxi board into 123 individual defconfig files. But the U-Boot start address for Allwinner boards is a platform decision which has been around for ages, so defining it in each *board* config file seems a bit over the top. Define the standard values (160MB into DRAM for most SoCs, with two SoC exceptions) if ARCH_SUNXI is selected, and delete the lines from the individual defconfigs. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-01sun50i: a64: Add initial Banana Pi M64 supportJagan Teki
BPI-M64 is a 64-bit quad-core mini single board computer using the Allwinner A64 SOC. BPI-M64 features - 1.2 Ghz Quad-Core ARM Cortex A53 - 2GB DDR3 SDRAM with 733MHz - MicroSD/eMMC(8GB) - 10/100/1000Mbps ethernet (Realtek RTL8211E/D) - Wifi + BT - IR receiver - Audio In/Out - Video In/Out - 5V 2A DC power-supply For dts file, Sync with Linux commit 4879b7ae("Merge tag 'dmaengine-4.12-rc1'"). Boot from MMC: ------------- U-Boot SPL 2017.05-00667-g85dd258-dirty (May 29 2017 - 13:07:31) DRAM: 2048 MiB Trying to boot from MMC1 NOTICE: BL3-1: Running on A64/H64 (1689) in SRAM A2 (@0x44000) NOTICE: Configuring SPC Controller NOTICE: BL3-1: v1.0(debug):aa75c8d NOTICE: BL3-1: Built : 18:28:27, May 24 2017 NOTICE: Configuring AXP PMIC NOTICE: PMIC: setup successful INFO: BL3-1: Initializing runtime services INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address: 0x4a000000, SPSR: 0x3c9 U-Boot 2017.05-00667-g85dd258-dirty (May 29 2017 - 13:07:31 +0000) Allwinner Technology CPU: Allwinner A64 (SUN50I) Model: BananaPi-M64 DRAM: 2 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: No ethernet found. starting USB... No controllers found Hit any key to stop autoboot: 0 Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
