path: root/configs/bananapi_m2_zero_defconfig
2019-04-10arm: sunxi: Enable DRAM ODT by default on H3/H5Paul Kocialkowski
Most of the boards we support with H3/H5 enable DRAM on-die termination, which is consistent with the high DRAM clocks that are used. Make it the default (like it's done for other similar platforms) instead of defining it in each defconfig. Signed-off-by: Paul Kocialkowski <paul.kocialkowski@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2019-04-10arm: sunxi: Set the default DRAM ZQ value to 3881979 on H3/H5Paul Kocialkowski
Most H3/H5 boards we support have the DRAM ZQ value set to 3881979, which is also consistent with the default set for the R40. Make this value the default on H3/H5 instead of 123. Signed-off-by: Paul Kocialkowski <paul.kocialkowski@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-10-31sunxi: add support for Banana Pi M2 Zero boardJun Nie
Banana Pi M2 Zero is a board by Sinovoip with Allwinner H2+ SoC, 16-bit 512MiB DDR3 memory, a MicroSD slot, two MicroUSB ports (one OTG and one powering-only) and a miniHDMI port. Signed-off-by: Icenowy Zheng <icenowy@aosc.io> Signed-off-by: Jun Nie <jun.nie@linaro.org> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> [jagan: Fixed board MAINTAINERS file] Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
