path: root/configs/axs103_defconfig
2019-02-09Convert CONFIG_BOARD_TYPES to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_BOARD_TYPES Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Acked-by: Alexey Brodkin <abrodkin@synopsys.com> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2019-02-07configs: Don't use SPI_FLASH_BAR as defaultVignesh R
Now that new SPI NOR layer uses stateless 4 byte opcodes by default, don't enable SPI_FLASH_BAR. For SPI controllers that cannot support 4-byte addressing, (stm32_qspi.c, fsl_qspi.c, mtk_qspi.c, ich.c, renesas_rpc_spi.c) add an imply clause to enable SPI_FLASH_BAR so as to not break functionality. Signed-off-by: Vignesh R <vigneshr@ti.com> Tested-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Tested-by: Stefan Roese <sr@denx.de> Tested-by: Horatiu Vultur <horatiu.vultur@microchip.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
2018-07-31AXS10x: add spi flash supportEugeniy Paltsev
AXS10x boards have n25q512 spi flash IC, so add corresponding nodes to device tree and enaple corresponding options in defconfig. Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2018-05-24ARC: enable debug uart for HSDK and AXS10x boardsEugeniy Paltsev
2018-04-17ARC: AXS10x: Enable hush shellEugeniy Paltsev
2017-07-31env: Migrate CONFIG_ENV_IS_IN_FAT options to KconfigTom Rini
We rename the various FAT_ENV_xxx options to CONFIG_ENV_FAT_xxx so that they can be modified via Kconfig. Migrate all existing users to the new values. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-25Convert CONFIG_ENV_IS_IN_FAT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ENV_IS_IN_FAT Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-29axs10x: Get rid of both I2C and EEPROM who used to use I2CAlexey Brodkin
With eb5ba3aefdf0 "i2c: Drop use of CONFIG_I2C_HARD" in place we cannot use I2C EEPROM any longer so we're dropping all references to both EEPROM and I2C which was only used for EEPROM. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Simon Glass <sjg@chromium.org>
2017-06-29axs10x: Add support of Ext2/4 FSAlexey Brodkin
Those could be easily used on USB flash drives or on SD/MMC cards. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2017-03-24arc: use timer driver for ARC boardsVlad Zakharov
This commit replaces legacy timer code with usage of arc timer driver. It removes arch/arc/lib/time.c file and selects CONFIG_CLK, CONFIG_TIMER and CONFIG_ARC_TIMER options for all ARC boards by default. Therefore we remove CONFIG_CLK option from less common axs101 and axs103 defconfigs. Also it removes legacy CONFIG_SYS_TIMER_RATE config symbol from axs10x.h, tb100.h and nsim.h configs files as it is no longer required. Signed-off-by: Vlad Zakharov <vzakhar@synopsys.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-03-24arc: dts: separate single axs10x.dts fileVlad Zakharov
We want to use the same device tree blobs in both Linux and U-Boot for ARC boards. Earlier device tree sources in U-Boot were very simplified and hadn't been updated for quite a long period of time. So this commit is the first step on the road to unified device tree blobs. First of all we re-organize device tree sources for AXS10X boards. As AXS101 and AXS103 boards consist of AXS10X motherboard and AXC001 and AXC003 cpu tiles respectively we add corresponding device tree source files: axs10x_mb.dtsi for motherboard, axc001.dtsi and axc003.dtsi for cpu tiles and axs101.dts and axs103.dts to represent actual boards. Also we delete axs10x.dts as it is no longer used. One more important change - we add timer device to ARC skeleton device tree sources as both ARC700 and ARCHS cores contain such timer. We add core_clk nodes to abilis_tb100, nsim, axc001 and axc003 device tree sources as it is referenced via phandle from timer node in common skeleton.dtsi file. Signed-off-by: Vlad Zakharov <vzakhar@synopsys.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-11mmc: move CONFIG_DWMMC to Kconfig, renaming to CONFIG_MMC_DWMasahiro Yamada
This commit was created as follows: [1] Rename the option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_DWMMC/CONFIG_MMC_DW/g' [2] create the entry for MMC_DW in drivers/mmc/Kconfig (the prompt and help were copied from Linux) [3] run "tools/moveconfig.py -y MMC_DW" [4] add "depends on MMC_DW" to the MMC_DW_ROCKCHIP entry [5] Clean-up doc/README.socfpga by hand Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-08-07usb: add CONFIG_USB_OHCI_HCD in KconfigMasahiro Yamada
Add this option as a common config for all OHCI controllers. Its help message was copied from Linux. Also, I moved it below EHCI to respect the order in Linux's Kconfig. Add CONFIG_USB_OHCI_HCD=y to axs103_defconfig, which is the only user of OHCI_GENERIC. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-08-05arc: Rename AXS101 board to more generic AXS10xAlexey Brodkin
As of now we have 2 flavors of ARC SDP boards: 1) AXS101 - with ARC770 in ASIC 2) AXS103 - with ARC HS38 in FPGA Both options share exactly the same base-board and only differ with CPU-tiles in use. That means all peripherals are the same (they are implemented in FPGA on the base-board) and so generic board could be used for both. While at it: * Recreated defconfigs with savedefconfig * In include/configs/axs10x.h numerical sizes replaced with defines from linux/sizes.h for better readability. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-06-13axs103: Bump CPU frequency from 50MHz to 100MHzAlexey Brodkin
In the upcoming release of axs103 v1.1 CPU will run @100MHz which we support with that change. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2016-05-17i2c: config: Move SYS_I2C_DW to KconfigStefan Roese
This patch moves all appearances of CONFIG_SYS_I2C_DW from the config header to the defconfig files. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Alexey Brodkin <abrodkin@synopsys.com>
2015-12-21axs103: add support of generic OHCI USB 1.1 controllerAlexey Brodkin
This commit adds support of USB 1.1 storage media on AXS103 board. For some yet unknown reason USB 2.0 doesn't work on AXS103 board issuing messages like this: ------------------------>8------------------- AXS# usb start starting USB... USB0: USB EHCI 1.00 scanning bus 0 for devices... EHCI timed out on TD - token=0x80008c80 unable to get device descriptor (error=-1) 1 USB Device(s) found ------------------------>8------------------- As a work-around we're falling back to USB 1.1. Indeed it is much slower but at least USB storage devices are usable on AXS103. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org>
2015-12-08axs10x: add support of generic EHCI USB 2.0 controllerAlexey Brodkin
This commit adds support of USB 2.0 storage media on AXS10x boards. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org>
2015-11-18board: axs10x switch serial port and Ethernet to driver modelAlexey Brodkin
With this change Synopsys DesignWare SDP board is switched to driver model for both serial port (serial_dw) and Ethernet (Designware GMAC). This simplifies include/configs/axs101.h and allows for reuse of Linux's Device Tree description. For simplicity Linux's .dts files are not blindly copied but only very few extracts of them are really used (those that are supported in U-Boot at the moment). Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Reviewed-by: Simon Glass <sjg@chromium.org> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-07arc: make AXS101 default platformAlexey Brodkin
This fixes building in automated flow that doesn't use defconfigs. See discussion on that topic here: http://patchwork.ozlabs.org/patch/502558/ See similar patches for other architectures/platforms here: [1] http://git.denx.de/?p=u-boot.git;a=commit;h=ff560a13056a565a4e9ce1761bd04276a3cace88 [2] http://git.denx.de/?p=u-boot.git;a=commit;h=589907e2c187ec69b351c38ccda36730d25ab5d6 And while at it add missing shell prompt to axs103. Cc: Tom Rini <trini@konsulko.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-04-18Kconfig: Move CONFIG_DESIGNWARE_ETH to KconfigSimon Glass
Move this to Kconfig and clean up board config files that use it. Also rename it to CONFIG_ETH_DESIGNWARE to fit with the naming that exists in drivers/net/Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org> Version 1: Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-03arc: re-generate defconfigsAlexey Brodkin
Before that moment our defconfigs were manually modified with addition of new options. That means once anybody wants to add another option and re-genarate defconfig with "make defconfig" there will be lots of differences. So to make future modifications more clean we'll do bulk re-generation right away. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-02-13arc: introduce U-Boot port for ARCv2 ISAAlexey Brodkin
ARC HS and ARC EM are new cores based on ARCv2 ISA which is binary incompatible with ISAv1 (AKA ARCompact). Significant difference between ISAv2 and v1 is implementation of interrupt vector table. In v1 it is implemented in the same way as on many other architectures - as a special location where user may put whether code executed in place (if machine word of space is enough) or jump to a full-scale interrupt handler. In v2 interrupt table is just an array of adresses of real interrupt handlers. That requires a separate section for IVT that is not encoded as code by assembler. This change adds support for following cores: * ARC EM6 (simple 32-bit microcontroller without MMU) * ARC HS36 (advanced 32-bit microcontroller without MMU) * ARC HS38 (advanced 32-bit microcontroller with MMU) As a part of ARC HS38 new version of MMU (v4) was introduced. Also this change adds AXS131 board which is the same DW ARC SDP base board but with ARC HS38 CPU tile. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
