The current name is inconsistent with SPL which uses CONFIG_SPL_TEXT_BASE
and this makes it imposible to use CONFIG_VAL().
Rename it to resolve this problem.
This is defined automatically when needed, so drop it from the few
defconfig files that define it manually.
This option is fact really related to SPL. For U-Boot proper we always use
driver model for block devices, so CONFIG_BLK is enabled if block devices
are in use.
It is only for SPL that we have two cases:
- SPL_BLK is enabled, in which case we use driver model and blk-uclass.c
- SPL_BLK is not enabled, in which case (if we need block devices) we must
use blk_legacy.c
Rename the symbol to SPL_LEGACY_BLOCK to make this clear. This is
different enough from BLK and SPL_BLK that there should be no confusion.
- Convert a large number of CONFIG symbols to Kconfig. Of note is a
large chunk of USB symbols (and dead code removal), ensuring all
SPL/TPL/VPL symbols have an appropriate dependency, largely (but not
entirely) removing the testing of CONFIG_SPL_BUILD in board headers,
and allowing CONFIG_EXTRA_ENV_TEXT and CONFIG_EXTRA_ENV_SETTINGS to
co-exist as this facilities migration of many platforms.
CONFIG_SYS_SPL_MALLOC_SIZE
CONFIG_SYS_SPL_MALLOC_START
We introduce a default value here as well, and CONFIG_SYS_SPL_MALLOC to
control if we have a malloc pool or not.
CONFIG_SPL_BSS_START_ADDR
CONFIG_SPL_STACK
CONFIG_SPL_BSS_MAX_SIZE
CONFIG_SPL_MAX_FOOTPRINT
Note that the da850evm platforms were violating the "only use one" rule
here, and so now hard-code their BSS limit.
CONFIG_SPL_PAD_TO
CONFIG_SPL_MAX_SIZE
CONFIG_TPL_PAD_TO
CONFIG_TPL_MAX_SIZE
Note that we need to make TPL_MAX_SIZE be hex, and so move and convert the
existing places.
CONFIG_SPL_NAND_RAW_ONLY
CONFIG_SPL_NAND_SOFTECC
CONFIG_SYS_CBSIZE
CONFIG_SYS_PBSIZE
This matches what this support is called in the non-SPL case. The postfix
_SUPPORT is redundant as enabling Kconfig options implies support.
With this we can use CONFIG_IS_ENABLED() as needed.
Signed-off-by: Andrew Davis <afd@ti.com>
The most commonly used value today is 0x2000 and not 0x400. Rework the
Kconfig logic to use this more frequently used value as the default.
Cc: Andrew F. Davis <afd@ti.com>
Cc: Alex Nemirovsky <alex.nemirovsky@cortina-access.com>
Cc: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Alison Wang <alison.wang@nxp.com>
Cc: Anastasiia Lukianenko <anastasiia_lukianenko@epam.com>
Cc: Andes <uboot@andestech.com>
Cc: Andre Przywara <andre.przywara@arm.com>
Cc: Bharat Gooty <bharat.gooty@broadcom.com>
Cc: David Lechner <david@lechnology.com>
Cc: Dzmitry Sankouski <dsankouski@gmail.com>
Cc: Enric Balletbo i Serra <eballetbo@gmail.com>
Cc: Eugeniy Paltsev <paltsev@synopsys.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Gerald Kerma <dreagle@doukki.net>
Cc: Gregory CLEMENT <gregory.clement@bootlin.com>
Cc: Holger Brunck <holger.brunck@hitachienergy.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Cc: Jassi Brar <jaswinder.singh@linaro.org>
Cc: Kristian Amlie <kristian.amlie@northern.tech>
Cc: Krzysztof Kozlowski <krzk@kernel.org>
Cc: Liviu Dudau <liviu.dudau@foss.arm.com>
Cc: Luka Perkov <luka.perkov@sartura.hr>
Cc: Lukasz Majewski <lukma@denx.de>
Cc: Masami Hiramatsu <masami.hiramatsu@linaro.org>
Cc: Matthias Brugger <mbrugger@suse.com>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: Michael Walle <michael@walle.cc>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Cc: Oleksandr Andrushchenko <oleksandr_andrushchenko@epam.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Cc: Patrice Chotard <patrice.chotard@foss.st.com>
Cc: Paul Burton <paul.burton@mips.com>
Cc: Paul Kocialkowski <contact@paulk.fr>
Cc: Priyanka Jain <priyanka.jain@nxp.com>
Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Cc: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com>
Cc: Sergey Temerkhanov <s.temerkhanov@gmail.com>
Cc: Stefan Bosch <stefan_b@posteo.net>
Cc: Stephan Gerhold <stephan@gerhold.net>
Cc: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
Cc: Thomas Chou <thomas@wytron.com.tw>
Cc: Thomas Fitzsimmons <fitzsim@fitzsim.org>
Cc: Thomas Weber <weber@corscience.de>
Cc: Tony Dinh <mibodhi@gmail.com>
Cc: Trevor Woerner <twoerner@gmail.com>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: Vladimir Zapolskiy <vz@mleia.com>
Cc: liuhao <liuhao@phytium.com.cn>
Cc: lixinde <lixinde@phytium.com.cn>
Cc: shuyiqi <shuyiqi@phytium.com.cn>
Cc: weichangzheng <weichangzheng@phytium.com.cn>
Reviewed-by: Thomas Chou <thomas@wytron.com.tw>
Reviewed-by: Masami Hiramatsu <masami.hiramatsu@linaro.org>
Reviewed-by: Tony Dinh <mibodhi@gmail.com>
Reviewed-by: Patrice Chotard <patrice.chotard@foss.st.com>
Reviewed-by: Kristian Amlie <kristian.amlie@northern.tech>
The values CONFIG_SYS_USE_NANDFLASH and CONFIG_SYS_USE_MMC serve the
same purpose as CONFIG_SD_BOOT / CONFIG_NAND_BOOT so migrate to using
these switches instead as they're already in Kconfig.
Cc: Stelian Pop <stelian@popies.net>
Cc: Daniel Gorsulowski <daniel.gorsulowski@esd.eu>
Cc: Eugen Hristev <eugen.hristev@microchip.com>
CONFIG_RMII
Cc: Ramon Fried <rfried.dev@gmail.com>
CONFIG_ATMEL_LEGACY
CONFIG_AT91_GPIO_PULLUP
CONFIG_AT91SAM9260
CONFIG_AT91SAM9G20
CONFIG_AT91SAM9XE
CONFIG_AT91SAM9261
CONFIG_AT91SAM9263
CONFIG_AT91SAM9G45
CONFIG_AT91SAM9M10G45
CONFIG_AT91SAM9N12
CONFIG_AT91SAM9RL
CONFIG_AT91SAM9X5
CONFIG_SAM9X60
CONFIG_SAMA7G5
CONFIG_SAMA5D2
CONFIG_SAMA5D3
CONFIG_SAMA5D4
These options are already select'd as needed, so we're just cleaning up
files here.
CONFIG_MACB
CONFIG_SYS_NAND_U_BOOT_LOCATIONS
CONFIG_SYS_NAND_U_BOOT_OFFS
CONFIG_SYS_NAND_PAGE_COUNT
CONFIG_SPL_NAND_LOAD
CONFIG_SYS_NAND_BLOCK_SIZE
CONFIG_SYS_NAND_PAGE_SIZE
CONFIG_SYS_NAND_OOBSIZE
As this is only useful when booting with ATAGs, which are now largely
disabled, remove this value for the remaining platforms. We have a few
places in the code that had been testing for MACH_TYPE as a sort of
internal logic. Update those to use different but still correct CONFIG
symbols.
Cc: Phil Sutter <phil@nwl.cc>
Rename these options so that CONFIG_IS_ENABLED can be used with them.
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
Now that we have consistent usage, migrate this symbol to Kconfig.
Drop the _SUPPORT suffix so we can use CONFIG_IS_ENABLED() with this
option.
Reviewed-by: Alexandru Gagniuc <mr.nuke.me@gmail.com>
Signed-off-by: Alexandru Gagniuc <mr.nuke.me@gmail.com>
CONFIG_SPL_NAND_BASE
CONFIG_SPL_NAND_IDENT
CONFIG_SPL_NAND_DRIVERS
CONFIG_SPL_NAND_ECC
CONFIG_SPL_NAND_SIMPLE
This change allows more fine tuning of driver model based SPI support in
SPL and TPL. It is now possible to explicitly enable/disable the DM_SPI
support in SPL and TPL via Kconfig option.
Before this change it was necessary to use:
/* SPI Flash Configs */
#if defined(CONFIG_SPL_BUILD)
#undef CONFIG_DM_SPI
#undef CONFIG_DM_SPI_FLASH
#undef CONFIG_SPI_FLASH_MTD
#endif
in the ./include/configs/<board>.h, which is error prone and shall be
avoided when we strive to switch to Kconfig.
The goal of this patch:
Provide distinction for DM_SPI support in both U-Boot proper and SPL (TPL).
Valid use case is when U-Boot proper wants to use DM_SPI, but SPL must
still support non DM driver.
Another use case is the conversion of non DM/DTS SPI driver to support
DM/DTS. When such driver needs to work in both SPL and U-Boot proper, the
distinction is needed in Kconfig (also if SPL version of the driver
supports OF_PLATDATA).
In the end of the day one would have to support following use cases (in
single driver file - e.g. mxs_spi.c):
- U-Boot proper driver supporting DT/DTS
- U-Boot proper driver without DT/DTS support (deprecated)
- SPL driver without DT/DTS support
- SPL (and TPL) driver with DT/DTS (when the SoC has enough resources to
run full blown DT/DTS)
- SPL driver with DT/DTS and SPL_OF_PLATDATA (when one have constrained
environment with no fitImage and OF_LIBFDT support).
Some boards do require SPI support (with DM) in SPL (TPL) and some only
have DM_SPI{_FLASH} defined to allow compiling SPL.
This patch converts #ifdef CONFIG_DM_SPI* to #if CONFIG_IS_ENABLED(DM_SPI)
and provides corresponding defines in Kconfig.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Tested-by: Adam Ford <aford173@gmail.com> #da850-evm
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
[trini: Fixup a few platforms]
Due to how the Makefile logic is we currently get DM_SPI support in SPL
enabled by having DM_SPI enabled for full U-Boot but not having
CONFIG_SPL_DM_SPI set. Add this missing option to boards that were
inadvertently making use of it.
Cc: Adam Ford <aford173@gmail.com>
Cc: Akash Gajjar <akash@openedev.com>
Cc: Andy Yan <andy.yan@rock-chips.com>
Cc: Anup Patel <anup.patel@wdc.com>
Cc: Atish Patra <atish.patra@wdc.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Chee Hong Ang <chee.hong.ang@intel.com>
Cc: Chin-Liang See <clsee@altera.com>
Cc: Dalon Westergreen <dwesterg@gmail.com>
Cc: Dinh Nguyen <dinguyen@kernel.org>
Cc: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Cc: Jagan Teki <jagan@amarulasolutions.com>
Cc: Klaus Goger <klaus.goger@theobroma-systems.com>
Cc: Levin Du <djw@t-chip.com.cn>
Cc: Ley Foon Tan <ley.foon.tan@intel.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Luca Ceresoli <luca@lucaceresoli.net>
Cc: Mike Looijmans <mike.looijmans@topic.nl>
Cc: Nicolas Ferre <nicolas.ferre@microchip.com>
Cc: Palmer Dabbelt <palmer@dabbelt.com>
Cc: Paul Walmsley <paul.walmsley@sifive.com>
Cc: Pavel Machek <pavel@denx.de>
Cc: Peter Robinson <pbrobinson@gmail.com>
Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Suniel Mahesh <sunil@amarulasolutions.com>
Cc: Wolfgang Grandegger <wg@aries-embedded.de>
Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
CONFIG_AT91_GPIO
In a few boards we had overridden, intentionally, the value used for
CONFIG_SPL_LDSCRIPT. However, rather than using the ARCH value (arm)
they used the $(ARCH) variable in make. This doesn't help really, so
switch to a hard-coded value.
MTD support must be enabled when using mtdparts. Indeed, functions
like get_mtd_info(), get_mtd_device() and put_mtd_device() are in
drivers/mtd/mtd_uboot.c and are built only with CONFIG_MTD.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
Both symbols must be enabled when there is a raw NAND driver
selected. Also enable them when CONFIG_CMD_NAND is selected to avoid
breaking things when we'll further rework the MTD dependency
description.
[trini: Rebase and migrate a few more boards here]
Add more clarity by changing the Kconfig entry name.
[trini: Re-run migration, update a few more cases]
