path: root/configs/axm_defconfig
2016-06-26arm: at91: taurus/axm: add DM and DTS supportHeiko Schocher
add DM and DTS support for the at91 based siemens boards. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Andreas Bießmann <andreas@biessmann.org> [rebased on current ToT] Signed-off-by: Andreas Bießmann <andreas@biessmann.org>
2016-01-19axm/taurus: Enable tiny printf in SPLTom Rini
Both of these boards are very close to their limit and with some toolchains such as gcc 5.x are too large. Switch to tiny printf to reclaim some size. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-01-19arm, at91, axm: add SPL support for axmHeiko Schocher
add SPL support also for the axm board. Signed-off-by: Heiko Schocher <hs@denx.de>
