path: root/configs/at91sam9x5ek_spiflash_defconfig
2017-10-16configs: Resync with savedefconfigTom Rini
2017-09-29board: at91sam9x5ek: Convert to CONFIG_DM_VIDEOWenyou Yang
Convert the board to support the video driver model, add the device tree node, and remove the unnecessary code. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-14configs: at91: Remove CONFIG_SYS_EXTRA_OPTIONS assignmentWenyou Yang
To remove the assignment of CONFIG_SYS_EXTRA_OPTIONS option, which is deprecated, use the CONFIG_XXXX_BOOT options to indicate the boot media, and the SoC is selected by the board. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-08-26board: atmel: Use the new PIT timer driverWenyou.Yang@microchip.com
Use the Atmel PIT timer driver which supports the driver model and device tree. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-05-09board: at91sam9x5ek: Enable early debug UARTWenyou Yang
Enable the early debug UART to debug problems when an ICE or other debug mechanism is not available. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-09configs: at91sam9x5ek: Update to support DM/DTWenyou Yang
Update the configuration files to support the device tree and driver model. The device clock and pins configuration are handled by the clock and the pinctrl drivers respectively. Because the limitation of internal SRAM size, the SPL with driver model can't be supported, disable the SPL option. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2015-04-01ARM: atmel: at91sam9x5ek: enable spl supportBo Shen
Enable SPL support for at91sam9x5ek board. Now, it supports boot up from NAND flash and SPI flash. Signed-off-by: Bo Shen <voice.shen@atmel.com>
