path: root/configs/at91sam9x5ek_spiflash_defconfig
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2015-04-01ARM: atmel: at91sam9x5ek: enable spl supportBo Shen
Enable SPL support for at91sam9x5ek board. Now, it supports boot up from NAND flash and SPI flash. Signed-off-by: Bo Shen <voice.shen@atmel.com>
