path: root/configs/at91sam9x5ek_nandflash_defconfig
2019-01-21ARM: at91: Convert SPL_GENERATE_ATMEL_PMECC_HEADER to KconfigDerald D. Woods
This commit converts the following items to Kconfig: CONFIG_ATMEL_NAND_HWECC CONFIG_ATMEL_NAND_HW_PMECC CONFIG_PMECC_CAP CONFIG_PMECC_SECTOR_SIZE CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER [PMECC References] https://www.at91.com/linux4sam/bin/view/Linux4SAM/PmeccConfigure https://www.at91.com/linux4sam/bin/view/Linux4SAM/AT91Bootstrap [Mailing List Thread] https://lists.denx.de/pipermail/u-boot/2018-December/350666.html Fixes: 5541543f ("configs: at91: Remove CONFIG_SYS_EXTRA_OPTIONS assignment") [trini: Make the migration be size neutral and possibly not fix the above in all cases] Reported-by: Daniel Evans <photonthunder@gmail.com> Cc: Eugen Hristev <eugen.hristev@microchip.com> Signed-off-by: Derald D. Woods <woods.technical@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-10-22configs: at91: sam9x5: added FIT and iminfo supportEugen Hristev
Enabled FIT image support and iminfo command for FIT information. Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-07-21configs: Make NAND_BOOT and ONENAND_BOOT imply NANDAdam Ford
Some boards indicate support from booting NAND or ONENAND booting, but don't enable the CONFIG_NAND. This makes those boards imply NAND which will make enabling other flags that are dependent on CONFIG_NAND possible and easier to migrate. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-21Convert CONFIG_NAND_ATMEL to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_ATMEL Signed-off-by: Adam Ford <aford173@gmail.com>
2018-05-23configs: at91sam9x5ek: updated mtdparts variable in bootargsEugen Hristev
We have a new demo layout of our sama5 boards for the NAND Flash memory. According to this new layout, adjust the mtdparts variable in bootargs to align with this, which is available at : http://www.at91.com/linux4sam/bin/view/Linux4SAM/Sama5d3XplainedMainPage#NAND_Flash_demo_Memory_map, Based on original work by Wenyou Yang Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-04-06spi: atmel: default y if DM_SPI && ARCH_AT91Jagan Teki
ATMEL_SPI is now fully converted to driver-model and respective boards switch to DM_SPI as well, so make default y for ARCH_AT91 Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Wenyou Yang <wenyouya@gmail.com>
2017-10-16configs: Resync with savedefconfigTom Rini
2017-09-29board: at91sam9x5ek: Convert to CONFIG_DM_VIDEOWenyou Yang
Convert the board to support the video driver model, add the device tree node, and remove the unnecessary code. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-14configs: at91: Remove CONFIG_SYS_EXTRA_OPTIONS assignmentWenyou Yang
To remove the assignment of CONFIG_SYS_EXTRA_OPTIONS option, which is deprecated, use the CONFIG_XXXX_BOOT options to indicate the boot media, and the SoC is selected by the board. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-08-26board: atmel: Use the new PIT timer driverWenyou.Yang@microchip.com
Use the Atmel PIT timer driver which supports the driver model and device tree. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-05-09board: at91sam9x5ek: Enable early debug UARTWenyou Yang
Enable the early debug UART to debug problems when an ICE or other debug mechanism is not available. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-09configs: at91sam9x5ek: Update to support DM/DTWenyou Yang
Update the configuration files to support the device tree and driver model. The device clock and pins configuration are handled by the clock and the pinctrl drivers respectively. Because the limitation of internal SRAM size, the SPL with driver model can't be supported, disable the SPL option. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
