path: root/configs/at91sam9x5ek_mmc_defconfig
2020-02-06video: enable VIDEO_ANSI and all VIDEO_BBP optionsAnatolij Gustschin
This partially reverts changes by commit 2cc393f32fd9 ("video: make BPP and ANSI configs optional") since it caused issues with other boards (missing LCD console output on pinebook, x86 platform or sandbox). Enable all disabled options again and opt out of not supported color depth in board defconfigs. Signed-off-by: Anatolij Gustschin <agust@denx.de> Reported-by: Vagrant Cascadian <vagrant@debian.org>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-06video: make BPP and ANSI configs optionalAnatolij Gustschin
Many boards do not use all selected framebuffer depth configurations, for such boards there is some unused code in video and console uclass routines. Make depth specific code optional to avoid dead code and slightly reduce binary size. Also make ANSI code optional for the same reason. When i.e. using only VIDEO_BPP16 the code size shrinks (below values when using gcc-7.3.0): $ ./tools/buildman/buildman -b video-wip -sS wandboard ... 01: Merge git://git.denx.de/u-boot-sh 02: video: add guards around 16bpp/32bbp code 03: video: make BPP and ANSI configs optional arm: (for 1/1 boards) all -776.0 bss -8.0 text -768.0 Signed-off-by: Anatolij Gustschin <agust@denx.de> Tested-by: Eugen Hristev <eugen.hristev@microchip.com> Tested-by: Patrice Chotard <patrice.chotard@st.com> Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-12-03mtd: rename CONFIG_NAND -> CONFIG_MTD_RAW_NANDMiquel Raynal
Add more clarity by changing the Kconfig entry name. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> [trini: Re-run migration, update a few more cases] Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-11-07configs: Resync with savedefconfigTom Rini
2019-08-25mtd: nand: raw: Move CONFIG_SYS_NAND_USE_FLASH_BBT to KconfigStefan Roese
Convert CONFIG_SYS_NAND_USE_FLASH_BBT to Kconfig, update defconfigs, headers and whitelist. Please note that this symbol already was used in Kconfig (imply in CONFIG_NAND_ATMEL) which did not work, since this symbol was not available in Kconfig. This changes now with this patch and all boards with CONFIG_NAND_ATMEL will have BBT enabled. Which is what I also need on my GARDENA AT91SAM based board. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Miquel Raynal <miquel.raynal@bootlin.com> Cc: Gregory CLEMENT <gregory.clement@bootlin.com> [trini: Rework such that the configs are unchanged to start with] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-07-09at91, omap2plus: configs: migrate CONFIG_ENV_ to defconfigsMarkus Klotzbuecher
Enable the extended ENV options for AT91 and OMAP2PLUS in order to be able to use CONFIG_ENV_UBI_* on these architectures. As this change also makes the configs ENV_SIZE, ENV_SECT_SIZE, ENV_OFFSET visible to AT91 and OMAP2PLUS, migrate users of these to KConfig. This migration was run using an extended moveconfig.py which evaluates expressions such as "(512 << 10)". See patch ("moveconfig: expand simple expressions"). All modified boards were built with SOURCE_DATE_EPOCH=0 before and after the change and successfully confirmed that the identical binary is generated (the only exception was igep00x0, which does not define CONFIG_ENV_IS_IN_UBI in the original board header. Once that is defined, the test passes too). hs: rebased patch to: 68b90e57bc: "configs: tinker-rk3288 disable CONFIG_SPL_I2C_SUPPORT" Signed-off-by: Markus Klotzbuecher <markus.klotzbuecher@kistler.com> Cc: Heiko Schocher <hs@denx.de> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Tom Rini <trini@konsulko.com>
2019-03-04configs: at91: remove SPL_GENERATE_ATMEL_PMECC_HEADER from non-nand configsEugen Hristev
SPL_GENERATE_ATMEL_PMECC_HEADER will generate a header for the SPL for NAND information. The initial stage 1 bootloader will use this header in case the NAND flash doesn't support commands to retrieve sector size, etc. However this header is bad for different boot media, like MMC or SPI. In case SD_BOOT or SPI_BOOT is used, remove the config for this. Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2019-01-21ARM: at91: Convert SPL_GENERATE_ATMEL_PMECC_HEADER to KconfigDerald D. Woods
This commit converts the following items to Kconfig: CONFIG_ATMEL_NAND_HWECC CONFIG_ATMEL_NAND_HW_PMECC CONFIG_PMECC_CAP CONFIG_PMECC_SECTOR_SIZE CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER [PMECC References] https://www.at91.com/linux4sam/bin/view/Linux4SAM/PmeccConfigure https://www.at91.com/linux4sam/bin/view/Linux4SAM/AT91Bootstrap [Mailing List Thread] https://lists.denx.de/pipermail/u-boot/2018-December/350666.html Fixes: 5541543f ("configs: at91: Remove CONFIG_SYS_EXTRA_OPTIONS assignment") [trini: Make the migration be size neutral and possibly not fix the above in all cases] Reported-by: Daniel Evans <photonthunder@gmail.com> Cc: Eugen Hristev <eugen.hristev@microchip.com> Signed-off-by: Derald D. Woods <woods.technical@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-10-22configs: at91: sam9x5: added FIT and iminfo supportEugen Hristev
Enabled FIT image support and iminfo command for FIT information. Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-07-21Convert CONFIG_NAND_ATMEL to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_ATMEL Signed-off-by: Adam Ford <aford173@gmail.com>
2018-04-06spi: atmel: default y if DM_SPI && ARCH_AT91Jagan Teki
ATMEL_SPI is now fully converted to driver-model and respective boards switch to DM_SPI as well, so make default y for ARCH_AT91 Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Wenyou Yang <wenyouya@gmail.com>
2017-10-16configs: Resync with savedefconfigTom Rini
2017-09-29board: at91sam9x5ek: Convert to CONFIG_DM_VIDEOWenyou Yang
Convert the board to support the video driver model, add the device tree node, and remove the unnecessary code. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-14configs: at91: Remove CONFIG_SYS_EXTRA_OPTIONS assignmentWenyou Yang
To remove the assignment of CONFIG_SYS_EXTRA_OPTIONS option, which is deprecated, use the CONFIG_XXXX_BOOT options to indicate the boot media, and the SoC is selected by the board. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-08-26board: atmel: Use the new PIT timer driverWenyou.Yang@microchip.com
Use the Atmel PIT timer driver which supports the driver model and device tree. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-07-31env: Migrate CONFIG_ENV_IS_IN_FAT options to KconfigTom Rini
We rename the various FAT_ENV_xxx options to CONFIG_ENV_FAT_xxx so that they can be modified via Kconfig. Migrate all existing users to the new values. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-25Convert CONFIG_ENV_IS_IN_FAT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ENV_IS_IN_FAT Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-09board: at91sam9x5ek: Enable early debug UARTWenyou Yang
Enable the early debug UART to debug problems when an ICE or other debug mechanism is not available. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-09configs: at91sam9x5ek: Update to support DM/DTWenyou Yang
Update the configuration files to support the device tree and driver model. The device clock and pins configuration are handled by the clock and the pinctrl drivers respectively. Because the limitation of internal SRAM size, the SPL with driver model can't be supported, disable the SPL option. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
