path: root/configs/at91sam9rlek_dataflash_defconfig
2015-03-18ARM: at91: at91sam9rlek: add hush parser to defconfigWu, Josh
HUSH parser will handle the variable easier. That will be helpful for write a complicated U-Boot commands or varaibles. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Bo Shen <voice.shen@atmel.com>
