path: root/configs/at91sam9n12ek_nandflash_defconfig
2017-09-14configs: at91: Remove CONFIG_SYS_EXTRA_OPTIONS assignmentWenyou Yang
To remove the assignment of CONFIG_SYS_EXTRA_OPTIONS option, which is deprecated, use the CONFIG_XXXX_BOOT options to indicate the boot media, and the SoC is selected by the board. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-08-26board: atmel: Use the new PIT timer driverWenyou.Yang@microchip.com
Use the Atmel PIT timer driver which supports the driver model and device tree. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-09board: at91sam9n12ek: Enable early debug UARTWenyou Yang
Enable the early debug UART to debug problems when an ICE or other debug mechanism is not available. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-09configs: at91sam9n12ek: Update for DT and DM supportWenyou Yang
Update the configuration files to support the device tree and driver model. The device clock and pins configuration are handled by the clock and the pinctrl drivers respectively. Because the limitation of internal SRAM size, the SPL with driver model can't be supported, disable the SPL option. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-01ARM: atmel: at91sam9n12ek: enable spl supportBo Shen
Enable SPL support for at91sam9n12ek boards, now it supports boot up from NAND flash, serial flash. Signed-off-by: Bo Shen <voice.shen@atmel.com>
