path: root/configs/at91sam9g20ek_2mmc_defconfig
2017-05-09board: at91sam9260ek/9g20ek: Enable early debug UARTWenyou Yang
Enable the early debug UART to debug problems when an ICE or other debug mechanism is not available. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-09configs: at91sam9260ek/9g20ek: Update for DT and DMWenyou Yang
Update the configuration files to support the device tree and driver model. The device clock and pins configuration are handled by the clock and the pinctrl drivers respectively. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-02-07ARM: at91: mmc portA support is only for at91sam9g20ek_2mmc boardWu, Josh
Current the MMC support will enable MCI port A, Which is only exist for 2mmc board. So by default we need to disable MMC (port A) support. And only enable it for 2mmc board. Otherwise, dataflash won't work in at91sam9260ek board as MMC has confliction with Dataflash in the CLK pin. Signed-off-by: Josh Wu <josh.wu@atmel.com>
