CONFIG_FLASH_SHOW_PROGRESS
CONFIG_SYS_MONITOR_LEN
To do this, we set a default of 0 for everyone because there are a
number of cases where we define CONFIG_SYS_MONITOR_LEN but the only
impact is that we set TOTAL_MALLOC_LEN to be CONFIG_SYS_MALLOC_LEN +
CONFIG_ENV_SIZE, so we must continue to allow all boards to set this
value. Update the SPL code to use 200 KB as the default raw U-Boot size
directly, if we don't have a real CONFIG_SYS_MONITOR_LEN value.
The struct is only used to overlay the MMIO region, so the behavior is
the same. This obsoletes the Kconfig option for the number of ports.
Signed-off-by: Samuel Holland <samuel@sholland.org>
The current name is inconsistent with SPL which uses CONFIG_SPL_TEXT_BASE
and this makes it imposible to use CONFIG_VAL().
Rename it to resolve this problem.
CONFIG_SYS_MAX_FLASH_SECT
CONFIG_SYS_OHCI_SWAP_REG_ACCESS
CONFIG_SYS_USB_OHCI_CPU_INIT
CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS
CONFIG_SYS_USB_OHCI_SLOT_NAME
CONFIG_USB_ATMEL
CONFIG_USB_ATMEL_CLK_SEL_PLLB
CONFIG_USB_ATMEL_CLK_SEL_UPLL
CONFIG_USB_OHCI_LPC32XX
CONFIG_USB_OHCI_NEW
CONFIG_SYS_CBSIZE
CONFIG_SYS_PBSIZE
The most commonly used value today is 0x2000 and not 0x400. Rework the
Kconfig logic to use this more frequently used value as the default.
Cc: Andrew F. Davis <afd@ti.com>
Cc: Alex Nemirovsky <alex.nemirovsky@cortina-access.com>
Cc: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Alison Wang <alison.wang@nxp.com>
Cc: Anastasiia Lukianenko <anastasiia_lukianenko@epam.com>
Cc: Andes <uboot@andestech.com>
Cc: Andre Przywara <andre.przywara@arm.com>
Cc: Bharat Gooty <bharat.gooty@broadcom.com>
Cc: David Lechner <david@lechnology.com>
Cc: Dzmitry Sankouski <dsankouski@gmail.com>
Cc: Enric Balletbo i Serra <eballetbo@gmail.com>
Cc: Eugeniy Paltsev <paltsev@synopsys.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Gerald Kerma <dreagle@doukki.net>
Cc: Gregory CLEMENT <gregory.clement@bootlin.com>
Cc: Holger Brunck <holger.brunck@hitachienergy.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Cc: Jassi Brar <jaswinder.singh@linaro.org>
Cc: Kristian Amlie <kristian.amlie@northern.tech>
Cc: Krzysztof Kozlowski <krzk@kernel.org>
Cc: Liviu Dudau <liviu.dudau@foss.arm.com>
Cc: Luka Perkov <luka.perkov@sartura.hr>
Cc: Lukasz Majewski <lukma@denx.de>
Cc: Masami Hiramatsu <masami.hiramatsu@linaro.org>
Cc: Matthias Brugger <mbrugger@suse.com>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: Michael Walle <michael@walle.cc>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Cc: Oleksandr Andrushchenko <oleksandr_andrushchenko@epam.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Cc: Patrice Chotard <patrice.chotard@foss.st.com>
Cc: Paul Burton <paul.burton@mips.com>
Cc: Paul Kocialkowski <contact@paulk.fr>
Cc: Priyanka Jain <priyanka.jain@nxp.com>
Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Cc: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com>
Cc: Sergey Temerkhanov <s.temerkhanov@gmail.com>
Cc: Stefan Bosch <stefan_b@posteo.net>
Cc: Stephan Gerhold <stephan@gerhold.net>
Cc: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
Cc: Thomas Chou <thomas@wytron.com.tw>
Cc: Thomas Fitzsimmons <fitzsim@fitzsim.org>
Cc: Thomas Weber <weber@corscience.de>
Cc: Tony Dinh <mibodhi@gmail.com>
Cc: Trevor Woerner <twoerner@gmail.com>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: Vladimir Zapolskiy <vz@mleia.com>
Cc: liuhao <liuhao@phytium.com.cn>
Cc: lixinde <lixinde@phytium.com.cn>
Cc: shuyiqi <shuyiqi@phytium.com.cn>
Cc: weichangzheng <weichangzheng@phytium.com.cn>
Reviewed-by: Thomas Chou <thomas@wytron.com.tw>
Reviewed-by: Masami Hiramatsu <masami.hiramatsu@linaro.org>
Reviewed-by: Tony Dinh <mibodhi@gmail.com>
Reviewed-by: Patrice Chotard <patrice.chotard@foss.st.com>
Reviewed-by: Kristian Amlie <kristian.amlie@northern.tech>
CONFIG_SYS_MONITOR_BASE
Note that for how this is re-used on some PowePC platforms, we introduce
CONFIG_SPL_SYS_MONITOR_BASE and CONFIG_TPL_SYS_MONITOR_BASE and use the
CONFIG_VAL macro to get the correct value at build time, in the code.
CONFIG_SYS_USE_NORFLASH
CONFIG_SYS_USE_BOOT_NORFLASH
CONFIG_ATMEL_LCD
CONFIG_ATMEL_LCD_BGR555
CONFIG_ATMEL_LCD_RGB565
CONFIG_GURNARD_SPLASH
CONFIG_RESET_PHY_R
Cc: Ramon Fried <rfried.dev@gmail.com>
CONFIG_ATMEL_LEGACY
Cc: Eugen Hristev <eugen.hristev@microchip.com>
CONFIG_AT91SAM9260
CONFIG_AT91SAM9G20
CONFIG_AT91SAM9XE
CONFIG_AT91SAM9261
CONFIG_AT91SAM9263
CONFIG_AT91SAM9G45
CONFIG_AT91SAM9M10G45
CONFIG_AT91SAM9N12
CONFIG_AT91SAM9RL
CONFIG_AT91SAM9X5
CONFIG_SAM9X60
CONFIG_SAMA7G5
CONFIG_SAMA5D2
CONFIG_SAMA5D3
CONFIG_SAMA5D4
These options are already select'd as needed, so we're just cleaning up
files here.
CONFIG_BOOTP_MAY_FAIL
CONFIG_BOOTP_VENDOREX
CONFIG_BOOTP_BOOTFILESIZE
CONFIG_BOOTP_NISDOMAIN
CONFIG_BOOTP_TIMEOFFSET
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Now that we have consistent usage, migrate this symbol to Kconfig.
As highlighted by Stefan in the commit e074d0f79b2e ("arm: at91:
gardena-smart-gateway-at91sam: Enable CONFIG_SYS_NAND_USE_FLASH_BBT")
it's important to use BBT when Linux enables it. We use it for a long
time on all our boards.
Signed-off-by: Nicolas Ferre <nicolas.ferre@microchip.com>
Cc: Stefan Roese <sr@denx.de>
Acked-by: Alexander Dahl <ada@thorsis.com>
DM_VIDEO conversion deadline has passed, disable VIDEO config.
Both symbols must be enabled when there is a raw NAND driver
selected. Also enable them when CONFIG_CMD_NAND is selected to avoid
breaking things when we'll further rework the MTD dependency
description.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
[trini: Rebase and migrate a few more boards here]
Add more clarity by changing the Kconfig entry name.
[trini: Re-run migration, update a few more cases]
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Move this symbol to Kconfig. As part of this we can drop a UBI-specific
symbol that was a stop-gap for not having this particular symbol in
Kconfig.
Convert CONFIG_SYS_NAND_USE_FLASH_BBT to Kconfig, update defconfigs,
headers and whitelist.
Please note that this symbol already was used in Kconfig
(imply in CONFIG_NAND_ATMEL) which did not work, since this symbol was
not available in Kconfig. This changes now with this patch and all
boards with CONFIG_NAND_ATMEL will have BBT enabled. Which is what
I also need on my GARDENA AT91SAM based board.
Cc: Miquel Raynal <miquel.raynal@bootlin.com>
[trini: Rework such that the configs are unchanged to start with]
CONFIG_ARCH_CPU_INIT
Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Tested-by: Felix Brack <fb@ltec.ch>
Enable the extended ENV options for AT91 and OMAP2PLUS in order to be
able to use CONFIG_ENV_UBI_* on these architectures.
As this change also makes the configs ENV_SIZE, ENV_SECT_SIZE,
ENV_OFFSET visible to AT91 and OMAP2PLUS, migrate users of these to
KConfig.
This migration was run using an extended moveconfig.py which evaluates
expressions such as "(512 << 10)". See patch ("moveconfig: expand
simple expressions").
All modified boards were built with SOURCE_DATE_EPOCH=0 before and
after the change and successfully confirmed that the identical binary
is generated (the only exception was igep00x0, which does not define
CONFIG_ENV_IS_IN_UBI in the original board header. Once that is
defined, the test passes too).
hs: rebased patch to:
68b90e57bc: "configs: tinker-rk3288 disable CONFIG_SPL_I2C_SUPPORT"
Signed-off-by: Markus Klotzbuecher <markus.klotzbuecher@kistler.com>
CONFIG_FLASH_CFI_DRIVER
CONFIG_SYS_FLASH_USE_BUFFER_WRITE
CONFIG_FLASH_CFI_MTD
CONFIG_SYS_FLASH_PROTECTION
CONFIG_SYS_FLASH_CFI
[trini: Re-migrate]
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
CONFIG_NAND_ATMEL
