CONFIG_SYS_OHCI_SWAP_REG_ACCESS
CONFIG_SYS_USB_OHCI_CPU_INIT
CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS
CONFIG_SYS_USB_OHCI_SLOT_NAME
CONFIG_USB_ATMEL
CONFIG_USB_ATMEL_CLK_SEL_PLLB
CONFIG_USB_ATMEL_CLK_SEL_UPLL
CONFIG_USB_OHCI_LPC32XX
CONFIG_USB_OHCI_NEW
CONFIG_SYS_CBSIZE
CONFIG_SYS_PBSIZE
The most commonly used value today is 0x2000 and not 0x400. Rework the
Kconfig logic to use this more frequently used value as the default.
Cc: Andrew F. Davis <afd@ti.com>
Cc: Alex Nemirovsky <alex.nemirovsky@cortina-access.com>
Cc: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Alison Wang <alison.wang@nxp.com>
Cc: Anastasiia Lukianenko <anastasiia_lukianenko@epam.com>
Cc: Andes <uboot@andestech.com>
Cc: Andre Przywara <andre.przywara@arm.com>
Cc: Bharat Gooty <bharat.gooty@broadcom.com>
Cc: David Lechner <david@lechnology.com>
Cc: Dzmitry Sankouski <dsankouski@gmail.com>
Cc: Enric Balletbo i Serra <eballetbo@gmail.com>
Cc: Eugeniy Paltsev <paltsev@synopsys.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Gerald Kerma <dreagle@doukki.net>
Cc: Gregory CLEMENT <gregory.clement@bootlin.com>
Cc: Holger Brunck <holger.brunck@hitachienergy.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Cc: Jassi Brar <jaswinder.singh@linaro.org>
Cc: Kristian Amlie <kristian.amlie@northern.tech>
Cc: Krzysztof Kozlowski <krzk@kernel.org>
Cc: Liviu Dudau <liviu.dudau@foss.arm.com>
Cc: Luka Perkov <luka.perkov@sartura.hr>
Cc: Lukasz Majewski <lukma@denx.de>
Cc: Masami Hiramatsu <masami.hiramatsu@linaro.org>
Cc: Matthias Brugger <mbrugger@suse.com>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: Michael Walle <michael@walle.cc>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Cc: Oleksandr Andrushchenko <oleksandr_andrushchenko@epam.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Cc: Patrice Chotard <patrice.chotard@foss.st.com>
Cc: Paul Burton <paul.burton@mips.com>
Cc: Paul Kocialkowski <contact@paulk.fr>
Cc: Priyanka Jain <priyanka.jain@nxp.com>
Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Cc: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com>
Cc: Sergey Temerkhanov <s.temerkhanov@gmail.com>
Cc: Stefan Bosch <stefan_b@posteo.net>
Cc: Stephan Gerhold <stephan@gerhold.net>
Cc: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
Cc: Thomas Chou <thomas@wytron.com.tw>
Cc: Thomas Fitzsimmons <fitzsim@fitzsim.org>
Cc: Thomas Weber <weber@corscience.de>
Cc: Tony Dinh <mibodhi@gmail.com>
Cc: Trevor Woerner <twoerner@gmail.com>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: Vladimir Zapolskiy <vz@mleia.com>
Cc: liuhao <liuhao@phytium.com.cn>
Cc: lixinde <lixinde@phytium.com.cn>
Cc: shuyiqi <shuyiqi@phytium.com.cn>
Cc: weichangzheng <weichangzheng@phytium.com.cn>
Reviewed-by: Thomas Chou <thomas@wytron.com.tw>
Reviewed-by: Masami Hiramatsu <masami.hiramatsu@linaro.org>
Reviewed-by: Tony Dinh <mibodhi@gmail.com>
Reviewed-by: Patrice Chotard <patrice.chotard@foss.st.com>
Reviewed-by: Kristian Amlie <kristian.amlie@northern.tech>
There are a handful of variants around CONFIG_SYS_USE_DATAFLASH and none
of them now control anything further within their board config.h files,
so remove these from CONFIG_SYS_EXTRA_OPTIONS and then remove the empty
blocks in the board config.h files. In a few places further clean up
related logic.
CONFIG_ATMEL_LCD
CONFIG_ATMEL_LCD_BGR555
CONFIG_ATMEL_LCD_RGB565
CONFIG_GURNARD_SPLASH
CONFIG_RESET_PHY_R
Cc: Ramon Fried <rfried.dev@gmail.com>
CONFIG_ATMEL_LEGACY
Cc: Eugen Hristev <eugen.hristev@microchip.com>
CONFIG_AT91SAM9260
CONFIG_AT91SAM9G20
CONFIG_AT91SAM9XE
CONFIG_AT91SAM9261
CONFIG_AT91SAM9263
CONFIG_AT91SAM9G45
CONFIG_AT91SAM9M10G45
CONFIG_AT91SAM9N12
CONFIG_AT91SAM9RL
CONFIG_AT91SAM9X5
CONFIG_SAM9X60
CONFIG_SAMA7G5
CONFIG_SAMA5D2
CONFIG_SAMA5D3
CONFIG_SAMA5D4
These options are already select'd as needed, so we're just cleaning up
files here.
CONFIG_BOOTP_MAY_FAIL
CONFIG_BOOTP_VENDOREX
CONFIG_BOOTP_BOOTFILESIZE
CONFIG_BOOTP_NISDOMAIN
CONFIG_BOOTP_TIMEOFFSET
CONFIG_ENV_SPI_BUS
CONFIG_ENV_SPI_CS
CONFIG_ENV_SPI_MAX_HZ
CONFIG_ENV_SPI_MODE
As part of this, we use Kconfig to provide the defaults now that were
done in include/spi_flash.h. We also in some cases change from using
CONFIG_ENV_SPI_FOO to CONFIG_SF_DEFAULT_FOO as those were the values in
use anyhow as ENV was not enabled.
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
Now that we have consistent usage, migrate this symbol to Kconfig.
As highlighted by Stefan in the commit e074d0f79b2e ("arm: at91:
gardena-smart-gateway-at91sam: Enable CONFIG_SYS_NAND_USE_FLASH_BBT")
it's important to use BBT when Linux enables it. We use it for a long
time on all our boards.
Signed-off-by: Nicolas Ferre <nicolas.ferre@microchip.com>
Cc: Stefan Roese <sr@denx.de>
Acked-by: Alexander Dahl <ada@thorsis.com>
DM_VIDEO conversion deadline has passed, disable VIDEO config.
Both symbols must be enabled when there is a raw NAND driver
selected. Also enable them when CONFIG_CMD_NAND is selected to avoid
breaking things when we'll further rework the MTD dependency
description.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
[trini: Rebase and migrate a few more boards here]
Add more clarity by changing the Kconfig entry name.
[trini: Re-run migration, update a few more cases]
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Convert CONFIG_SYS_NAND_USE_FLASH_BBT to Kconfig, update defconfigs,
headers and whitelist.
Please note that this symbol already was used in Kconfig
(imply in CONFIG_NAND_ATMEL) which did not work, since this symbol was
not available in Kconfig. This changes now with this patch and all
boards with CONFIG_NAND_ATMEL will have BBT enabled. Which is what
I also need on my GARDENA AT91SAM based board.
Cc: Miquel Raynal <miquel.raynal@bootlin.com>
[trini: Rework such that the configs are unchanged to start with]
CONFIG_ARCH_CPU_INIT
Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Tested-by: Felix Brack <fb@ltec.ch>
Enable the extended ENV options for AT91 and OMAP2PLUS in order to be
able to use CONFIG_ENV_UBI_* on these architectures.
As this change also makes the configs ENV_SIZE, ENV_SECT_SIZE,
ENV_OFFSET visible to AT91 and OMAP2PLUS, migrate users of these to
KConfig.
This migration was run using an extended moveconfig.py which evaluates
expressions such as "(512 << 10)". See patch ("moveconfig: expand
simple expressions").
All modified boards were built with SOURCE_DATE_EPOCH=0 before and
after the change and successfully confirmed that the identical binary
is generated (the only exception was igep00x0, which does not define
CONFIG_ENV_IS_IN_UBI in the original board header. Once that is
defined, the test passes too).
hs: rebased patch to:
68b90e57bc: "configs: tinker-rk3288 disable CONFIG_SPL_I2C_SUPPORT"
Signed-off-by: Markus Klotzbuecher <markus.klotzbuecher@kistler.com>
CONFIG_ENV_SPI_BUS
CONFIG_ENV_SPI_CS
CONFIG_ENV_SPI_MODE
Most of time these value are not needed, CONFIG_SF_DEFAULT
with same value is used, so I introduced CONFIG_USE_ENV_SPI_*
to force the associated value for the environment.
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
CONFIG_NAND_ATMEL
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
ATMEL_SPI is now fully converted to driver-model and
respective boards switch to DM_SPI as well,
so make default y for ARCH_AT91
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Acked-by: Wenyou Yang <wenyouya@gmail.com>
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
