path: root/configs/at91sam9263ek_dataflash_cs0_defconfig
2017-08-26board: atmel: Use the new PIT timer driverWenyou.Yang@microchip.com
Use the Atmel PIT timer driver which supports the driver model and device tree. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-08-04board: at91sam9263ek: Use SPI-flash-based AT45xxx DataFlashWenyou.Yang@microchip.com
To support driver model and device tree, use the SPI-flash-based AT45xxx DataFlash driver, DataFlash is a kind of SPI flash. Instead of ATMEL_DATAFLASH_SPI DataFlash older driver that will be removed in the future. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-25Convert CONFIG_ENV_IS_IN_DATAFLASH to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ENV_IS_IN_DATAFLASH Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-09board: at91sam9263ek: Enable early debug UARTWenyou Yang
Enable the early debug UART to debug problems when an ICE or other debug mechanism is not available. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-09configs: at91sam9263ek: Update for DT and DM supportWenyou Yang
Update the configuration files to support the device tree and driver model. The device clock and pins configuration are handled by the clock and the pinctrl drivers respectively. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
