path: root/configs/astro_mcf5373l_defconfig
2018-02-28fpga: Added Kconfig support for FPGA_SPARTAN3Vipul Kumar
This patch added Kconfig support for FPGA_SPARTAN3 and migrates the values over to the defconfigs. Signed-off-by: Vipul Kumar <vipulk@xilinx.com> Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
2018-02-27Kconfig: cmd: Make networking command dependent on NETMichal Simek
Enable networking command only when NET is enabled. And remove selecting NET for CMD_NET Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-05fpga: Resync various CONFIG_FPGA_* symbolsTuomas Tynkkynen
These are declared in Kconfig, but some #defines have crept in. CONFIG_FPGA CONFIG_FPGA_ALTERA CONFIG_FPGA_CYCLON2 CONFIG_FPGA_SOCFPGA CONFIG_FPGA_XILINX CONFIG_FPGA_ZYNQMPPL Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2017-07-26kconfig: Convert FPGA and FPGA_ALTERA configuration to KconfigTien Fong Chee
This converts the following to Kconfig: CONFIG_FPGA CONFIG_FPGA_ALTERA Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Ley Foon Tan <ley.foon.tan@intel.com> Reviewed-by: Dinh Nguyen <dinguyen@kernel.org>
2017-05-22Convert CONFIG_CMD_JFFS2 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_JFFS2 Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_FPGA_LOADBP et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_FPGA_LOADBP CONFIG_CMD_FPGA_LOADFS CONFIG_CMD_FPGA_LOADMK CONFIG_CMD_FPGA_LOADP Signed-off-by: Simon Glass <sjg@chromium.org>
