path: root/configs/astro_mcf5373l_defconfig
2017-07-26kconfig: Convert FPGA and FPGA_ALTERA configuration to KconfigTien Fong Chee
This converts the following to Kconfig: CONFIG_FPGA CONFIG_FPGA_ALTERA Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Ley Foon Tan <ley.foon.tan@intel.com> Reviewed-by: Dinh Nguyen <dinguyen@kernel.org>
2017-05-22Convert CONFIG_CMD_JFFS2 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_JFFS2 Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_FPGA_LOADBP et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_FPGA_LOADBP CONFIG_CMD_FPGA_LOADFS CONFIG_CMD_FPGA_LOADMK CONFIG_CMD_FPGA_LOADP Signed-off-by: Simon Glass <sjg@chromium.org>
