path: root/configs/aristainetos2_defconfig
2018-02-13spi: Migrate CONFIG_MXC_SPI to KconfigTuomas Tynkkynen
2018-02-08Convert CONFIG_NAND_MXS to KconfigStefan Agner
This converts CONFIG_NAND_MXS to Kconfig. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-10-30configs: Resync with savedefconfigTom Rini
2017-08-07Move PHY_MICREL and PHY_MICREL_KSZ90X1 to KconfigAlexandru Gagniuc
2016-10-23Convert CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VIDEO_SW_CURSOR to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VIDEO_SW_CURSOR Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-convert, find all the cases where this is off] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2015-09-02imx: mx6 move TARGET_xx Kconfig option to mx6 specific Kconfig filePeng Fan
Move TARGET_xx Kconfig option based on mx6 to arch/arm/cpu/armv7/mx6/Kconfig. Add enable "CONFIG_ARCH_MX6" for boards based on mx6. Then we can choose target boards using "make ARCH=arm menuconfig" with ARCH_MX6 defined. If using original way, we have no chance to enable ARCH_MX6 when "make menuconfig". Even define CONFIG_ARCH_MX6=y in xx_defconfig, kconfig will complains "arch/../configs/platinum_titanium_defconfig:3: warning: override: TARGET_PLATINUM_TITANIUM changes choice state" Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Eric BĂ©nard <eric@eukrea.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Marek Vasut <marex@denx.de> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Soeren Moch <smoch@web.de> Cc: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Soeren Moch <smoch@web.de> Acked-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2015-05-26arm, imx6: add support for aristainetos2 boardHeiko Schocher
add support for imx6dl based aristainetos2 board U-Boot 2015.04-rc5-00066-g60f6ed4 (Apr 10 2015 - 08:46:27) CPU: Freescale i.MX6DL rev1.1 at 792 MHz Reset cause: WDOG Board: aristaitenos2 Watchdog enabled I2C: ready DRAM: 1 GiB NAND: 1024 MiB MMC: FSL_SDHC: 0 SF: Detected N25Q128A with page size 256 Bytes, erase size 64 KiB, total 16 MiB Display: lg4573 (480x800) In: serial Out: serial Err: serial Net: FEC [PRIME] Hit any key to stop autoboot: 0 => Signed-off-by: Heiko Schocher <hs@denx.de>
